You have an A record for bestinslot.org, but not for forum.bestinslot.org (or bless, for that matter). You need a DNS record for each subdomain you want to exist.
thought maybe it was my firewall, but I have 443 open… hmm.
Failed authorization procedure. bless.bestinslot.org (tls-sni-01): urn:acme:erro r:connection :: The server could not connect to the client to verify the domain :: Connection refused, forum.bestinslot.org (tls-sni-01): urn:acme:error:connect ion :: The server could not connect to the client to verify the domain :: Connec tion refused
It was an issue with bless.bestinslot.org, so just a server block config problem. I just excluded it since there really isn’t a site there to begin with and ill go back and include it later.
