DNS Challenge does not work
Hello Folks,
I have some trouble with obtaining a new wildcard certificate. Just three month ago it worked well with the dns challenge. This Week it wont work, and I can’t find out the problem.
I need one certificate it looks like certbot will make two of it.
dns-01 challenge for ulrichivens.de
Certbot asked me to put in two challenges, what I’d done. Between every change I waited a couple of hours to let it deploy.
At the end certbot said, that the txt record is incorrect but shows the correct one in the output. What can I do to get the new certificate? I want a manual install on my server configuration, what I’ve done before.
Kind Regards
Ulrich
ulrichivens.de
certbot certonly --server https://acme-v02.api.letsencrypt.org/directory --manual --preferred-challenges dns -d 'ulrichivens.de,*.ulrichivens.de'
** and that one in another terminal to check if deployed**
nslookup -type=TXT _acme-challenge.ulrichivens.de ns15.domserver.de
Server:		ns15.domserver.de
Address:	2001:4178:3:a357:62:116:159:35#53
_acme-challenge.ulrichivens.de	text = "Uhk7jfhAZ58INnNFNDjlPjm3va7ZrNJ9ZBQ7V0BnsqA"
_acme-challenge.ulrichivens.de	text = "gNJZEf9PfMbfuhlF1vhFmaINcxG-odIXDWIWd_KgXCM"
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you're running certbot in manual mode on a machine that is not
your server, please ensure you're okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: yes
Please deploy a DNS TXT record under the name
_acme-challenge.ulrichivens.de with the following value:
Before continuing, verify the record is deployed.
Press Enter to Continue
Failed authorization procedure. ulrichivens.de (dns-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect TXT record "gNJZEf9PfMbfuhlF1vhFmaINcxG-odIXDWIWd_KgXCM" found at _acme-challenge.ulrichivens.de
   Domain: ulrichivens.de
   Type:   unauthorized
   Detail: Incorrect TXT record
I manually install the certificate, that had worked in the past.
Ubuntu 18.04 LTS with all updates
Own Server
Yes
no
certbot --version
certbot 0.27.0
Hi @uivens
that's
expected. You want one certificate with
two domain names. So you need (same time!) two different TXT entries with the same name and different values.
If you overwrite the first value with the second value, the first value is missing -> that's wrong.
Create two entries with the same domain name _acme-challenge.
Thank you. That worked. In newer versions of certbot there is a hint to that in the cli.
