Hi there,
I am setting up owncloud on a Raspi
I am following these instructions
https://normally.online/2016/04/29/owncloud-9-0-1-on-raspberry-pi-3-step-by-step/
The creation of the cert fails with this message:
Domain: owncloud.martinschmitz.de
404 Not Found
Detail: Invalid response from
http://owncloud.martinschmitz.de/.well-known/acme-challenge/sa9nAwQNunAMUW4nbPLrSoA0dnijNF_sG5_p70E_qOQ:
"404 Not Found
"To fix these errors, please make sure that your domain name was
contain(s) the right IP address. -
If you check the DNS Name, you get to the server, so basic configuration seems ok.
DNS is maintanined by the upstream router - I never added the domain name on the Raspi - I think this might be the problem?
Can you please tell me what to do to make this work?
Thanks from Germany
Miles
