If you delete the second and the third, but one is used, this isn't a good idea.
You have your correct first certificate. So use it.
Now
DNS-Name: attend-class.com
DNS-Name: www.attend-class.com
you use the correct certificate, valid 2018-11-20, more then 2 months.
Now wait ~~ 30 days, 2018-10-22, if the renew works. If there is no renew 2018-11-01, ask again.
@davejoyce
Please start a new thread. Thanks.
jasemq
September 8, 2018, 2:01pm
26
will do. Thanks for your generous help
Osiris
September 8, 2018, 3:22pm
27
Depends on the distribution you're using I think. That's why I suggested to check if there is a timer or cronjob. If there's not, you can set one up manually.
system
Closed
October 8, 2018, 3:22pm
28
