Hi!
Nothing happens. https-sites still not working. And same message in the apache error_log as above (just in case).
Hi!
@aqwed11, it is really weird. If you can upload the conf files I could try to recreate your configuration in a Centos 6.9 Virtual Machine.
Just use this command as root:
tar zcvf communityLE.tar.gz /etc/letsencrypt/options-ssl-apache.conf /etc/httpd/
And upload the file communityLE.tar.gz to some public site.
Cheers,
sahsanu
Messaged link to tar to you.
Solution (thanks to @sahsanu)
1. Modify conf/httpd.conf file
Replace this line:
NameVirtualHost 217.170.72.27
with these two lines:
NameVirtualHost 217.170.72.27:80
NameVirtualHost 217.170.72.27:443
2. Modify conf.d/domain.conf file:
Replace this line:
<VirtualHost 217.170.72.27>
with this one:
<VirtualHost 217.170.72.27:80>
3. Modify conf.d/domain-le-ssl.conf file:
Remove/comment these lines:
<IfModule mod_ssl.c>
and
</IfModule>
The IfModule directive should work as expected but it doesn’t. mod_ssl is being used but the IfModule seems that is not detecting it so this conf file is not being loaded so.
4. Restart Apache.
