Changed that for both :80 and :443
The TLS section should look a lot more like:
[feel free to modify/add/remove anything as needed - this should be a good starting point]
<VirtualHost *:443>
ServerName www.apersonalvideo.com
ServerAlias apersonalvideo.com
DocumentRoot /var/www/html/
SSLProtocol +TLSv1.2
ProtocolsHonorOrder On
Protocols h2 http/1.1
SSLEngine On
SSLCertificateFile /etc/letsencrypt/live/apersonalvideo.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/apersonalvideo.com/privkey.pem
SSLCipherSuite EECDH+ECDSA:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:!3DES:!aNULL:!eNULL:!RC4
</VirtualHost>
And you need to update DNS:
Address: 52.9.144.44
*** UnKnown can’t find www.apersonalvideo.com: Non-existent domain
And when you get around to it, please explain that to me - I don't understand what you mean.
Do I need to change the Virtual host section for :80?
Does it already work?
If “yes”, then leave it alone.
this can be removed - there is no cert for "localhost":
I replaced:
<VirtualHost *:443>
ServerName localhost
</VirtualHost>
With what you provided.
It is still not working.
You are confusing me…
Please show the current output of:
apachectl -S
apachectl -S
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/httpd/conf/httpd.conf:356
AH00526: Syntax error on line 378 of /etc/httpd/conf/httpd.conf:
Invalid command ‘SSLProtocol’, perhaps misspelled or defined by a module not included in the server configuration
Most likely, your config is missing:
LoadModule ssl_module modules/mod_ssl.so
apachectl -S
httpd: Syntax error on line 56 of /etc/httpd/conf/httpd.conf: Cannot load modules/mod_ssl.so into server: /etc/httpd/modules/mod_ssl.so: cannot open shared object file: No such file or directory
Try instead:
sudo a2enmod ssl
sudo: a2enmod: command not found
Then your apache version may be a bit “old”.
You should probably update it or check on Apache forums for HOW TO enable SSL/TLS for your specific version.
Try:
apache2 -version
httpd -version
httpd -v
Server version: Apache/2.4.41 (Amazon)
Looks current according to https://httpd.apache.org/download.cgi
Well then search: “HOW TO enable TLS on Amazon Apache2/2.4.41”
Unfortunately, this is an LE forum and your cert is already current/up-to-date.
I did try…
Sadly, I don’t use Amazon.
One last thing: We may have missed adding a LISTEN 443 statement.
Right below that add:
Listen 0.0.0.0:443
and see: Configure SSL/TLS on Amazon Linux - Amazon Elastic Compute Cloud
Thank you for your help.
I am still having a problem with:
Not your problem, so I will take it from here.
As for the comment about software testing, have you seen any other initial posts with as much documented?
