CSR parsing fails on specific Key Usage?
It appears that having a Key Usage ext on CSR triggers failure to parse the CSR on boulder side. Not always though, but only if “critical” is set. For example:
    Requested Extensions:
        X509v3 Key Usage:
            Digital Signature, Key Encipherment
Works. But:
        X509v3 Key Usage: critical
Fails.
Could anyone on the dev team please confirm? Note - this is not the CSR generated by the client, this is an actual use case of CSR used with the client but generated by a specific networking equipment.
Yep, that’s a known bug triggered if there’s any extension with the critical flag in the CSR:
Should be fixed once boulder moves to Go 1.6.
Cheers, good to know. Any estimate on when the shift to 1.6 might happen?
