CRON timing for auto renewal
OSX
YES
NO
acme script
Script runs fine and renews (when running under root and executed manually) am very comforatable creating cron jobs, my issue is if i have the script to run everyday is there a limitation for ENQUIRING / renewing the certificate (3 months?) or do i have to have the cron script run more in line with the renewal date 2.5 months from the last only one or so calls per 3 months. I havnt created the cron job however just want to make sure i dont hit any limitation on asking everday “renew me?” Also is this why people use certbot as it has more checks an balances than the basic acme script ?
Contents of acme script below
./acme.sh/acme.sh --issue -d DOMAIN --standalone --httpport 8081
/usr/local/kerio/mailserver/keriomailserver stop
cp ~/.acme.sh/domain.name/domain.name.cer /usr/local/kerio/mailserver/sslcert/server2.crt
cp ~/.acme.sh/domain.name/domain.name.key /usr/local/kerio/mailserver/sslcert/server2.key
/usr/local/kerio/mailserver/keriomailserver start
What you’d really want to do is put the remaining commands (the ones after acme.sh) into a post-renew script. Then issue the cert with acme.sh --issue -d DOMAIN --standalone --httpport 8081 --reloadcmd /path/to/script. Once that issues, set a daily cron job of /path/to/acme.sh --cron.
You should also use acme.sh --install to copy the certificate and key files instead of cp.
Daily, at random times of the day.
For example, with something like:
0 */12 * * * perl -e 'sleep int(rand(43200))' && /path/to/acme.sh --cron
Or an equivalent that works on macOS.
Thanyou both for insight ! Would the below be correct ?
./acme.sh/acme.sh --issue -d DOMAIN --standalone --httpport 8081 --reloadcmd
–install ~/.acme.sh/domain.name/domain.name.cer /usr/local/kerio/mailserver/sslcert/server2.crt
–install ~/.acme.sh/domain.name/domain.name.key /usr/local/kerio/mailserver/sslcert/server2.key
As the server has daily backups i dont want the script to impede on that so a “not so” randomised time 90 minutes after 21:30pm
30 21 * * * bash -c “sleep $[RANDOM%90]m” ; ~/var/root/scripts/acme.sh
After further consideration, the way to go would be
.acme.sh/acme.sh --issue -d DOMAIN --standalone --httpport 8081 --key-file /usr/local/kerio/mailserver/sslcert/server2.key --cert-file /usr/local/kerio/mailserver/sslcert/server2.crt --reloadcmd /usr/local/kerio/mailserver/keriomailserver restart (assuming there’s a “restart” command for keriomailserver, “reload” would be even better). Then your cron job (after whatever delay you implement) would still be what I suggested earlier: acme.sh --cron.
Consider whether you’d need to use --fullchain-file rather than --cert-file; that’s going to depend on the requirements of your server software.
