crontab -l
no crontab for root
root@genesis:/etc/letsencrypt/renewal#
Let's have a look at these files:
And as a comparison/contrast:
What about?:
And also:
certbot certificates
Here are the files
# cat kibana.allenintech.com.conf
#renew_before_expiry = 30 days
version = 1.32.1
archive_dir = /etc/letsencrypt/archive/kibana.allenintech.com
cert = /etc/letsencrypt/live/kibana.allenintech.com/cert.pem
privkey = /etc/letsencrypt/live/kibana.allenintech.com/privkey.pem
chain = /etc/letsencrypt/live/kibana.allenintech.com/chain.pem
fullchain = /etc/letsencrypt/live/kibana.allenintech.com/fullchain.pem
#Options used in the renewal process
[renewalparams]
authenticator = standalone
account = 167f86e1432ceed045ef851b5bae590f
key_type = rsa
# cat www.elasticsearch.allenintech.com.conf
version = 1.26.0
archive_dir = /etc/letsencrypt/archive/www.elasticsearch.allenintech.com
cert = /etc/letsencrypt/live/www.elasticsearch.allenintech.com/cert.pem
privkey = /etc/letsencrypt/live/www.elasticsearch.allenintech.com/privkey.pem
chain = /etc/letsencrypt/live/www.elasticsearch.allenintech.com/chain.pem
fullchain = /etc/letsencrypt/live/www.elasticsearch.allenintech.com/fullchain.pem
[renewalparams]
key_type = rsa
# cat www.kibana.allenintech.com.conf
version = 1.32.1
archive_dir = /etc/letsencrypt/archive/www.kibana.allenintech.com
cert = /etc/letsencrypt/live/www.kibana.allenintech.com/cert.pem
privkey = /etc/letsencrypt/live/www.kibana.allenintech.com/privkey.pem
chain = /etc/letsencrypt/live/www.kibana.allenintech.com/chain.pem
fullchain = /etc/letsencrypt/live/www.kibana.allenintech.com/fullchain.pem
[renewalparams]
authenticator = apache
key_type = rsa
installer = apache
See the problem?
So it is a cron job. as stated by OP in the initial post.
The authenticator should be apache?
The authenticators?
I should correct authenticator standalone to apache?
also installer = apache
I would.
But your Apache
configuration must be working properly [for that to succeed].
The certs should already be installed; So, that's not really necessary.
What shows?:
OK
I'll update standalone to apache and rerun dry-run
Nicely done, @rg305!
So can we get the cron working. I go up the thread and pick up your other suggestions.
root@genesis:/etc/letsencrypt/renewal# PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin certbot renew --dry-run
Processing /etc/letsencrypt/renewal/allenintech.com-0002.conf
Simulating renewal of an existing certificate for allenintech.com
Processing /etc/letsencrypt/renewal/kibana.allenintech.com.conf
Simulating renewal of an existing certificate for kibana.allenintech.com
Processing /etc/letsencrypt/renewal/nextcloud.allenintech.com-0001.conf
Simulating renewal of an existing certificate for nextcloud.allenintech.com and www.nextcloud.allenintech.com
Processing /etc/letsencrypt/renewal/www.elasticsearch.allenintech.com.conf
Simulating renewal of an existing certificate for www.elasticsearch.allenintech.com and elasticsearch.allenintech.com
Processing /etc/letsencrypt/renewal/www.kibana.allenintech.com.conf
Simulating renewal of an existing certificate for kibana.allenintech.com and www.kibana.allenintech.com
Congratulations, all simulated renewals succeeded:
/etc/letsencrypt/live/allenintech.com-0002/fullchain.pem (success)
/etc/letsencrypt/live/kibana.allenintech.com/fullchain.pem (success)
/etc/letsencrypt/live/nextcloud.allenintech.com-0001/fullchain.pem (success)
/etc/letsencrypt/live/www.elasticsearch.allenintech.com/fullchain.pem (success)
/etc/letsencrypt/live/www.kibana.allenintech.com/fullchain.pem (success)
show Invalid: expired for the following
Certificate Name: www.elasticsearch.allenintech.com
Serial Number: 39dfcb8b2a052f8f17b6f0801817f91c334
Key Type: RSA
Domains: www.elasticsearch.allenintech.com elasticsearch.allenintech.com
Expiry Date: 2022-07-14 14:20:05+00:00 (INVALID: EXPIRED)
Certificate Path: /etc/letsencrypt/live/www.elasticsearch.allenintech.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.elasticsearch.allenintech.com/privkey.pem
We need to check on the certs.
Every thing
Found the following certs:
Certificate Name: allenintech.com-0002
Serial Number: 3cc7e965a9bb2c90f99bda2cd7550641575
Key Type: RSA
Domains: allenintech.com
Expiry Date: 2023-01-31 02:06:17+00:00 (VALID: 46 days)
Certificate Path: /etc/letsencrypt/live/allenintech.com-0002/fullchain.pem
Private Key Path: /etc/letsencrypt/live/allenintech.com-0002/privkey.pem
Certificate Name: kibana.allenintech.com
Serial Number: 41020bd0c3f3656f0d60f727216fdc71af1
Key Type: RSA
Domains: kibana.allenintech.com
Expiry Date: 2023-03-14 09:37:40+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/kibana.allenintech.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/kibana.allenintech.com/privkey.pem
Certificate Name: nextcloud.allenintech.com-0001
Serial Number: 40c846a65d7c037d6ffb13f9ca935f17587
Key Type: RSA
Domains: nextcloud.allenintech.com www.nextcloud.allenintech.com
Expiry Date: 2023-01-31 05:07:46+00:00 (VALID: 47 days)
Certificate Path: /etc/letsencrypt/live/nextcloud.allenintech.com-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/nextcloud.allenintech.com-0001/privkey.pem
Key Type: RSA
Certificate Name: www.kibana.allenintech.com
Serial Number: 486d45a41d62df4114aafbc0d1cff5c8e58
Key Type: RSA
Domains: kibana.allenintech.com www.kibana.allenintech.com
Expiry Date: 2023-03-13 23:52:07+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/www.kibana.allenintech.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.kibana.allenintech.com/privkey.pem
This is concerning:
Let's try and renew it:
[PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin certbot renew
It renewed
Renewing an existing certificate for www.elasticsearch.allenintech.com and elasticsearch.allenintech.com
The following certificates are not due for renewal yet:
/etc/letsencrypt/live/allenintech.com-0002/fullchain.pem expires on 2023-01-31 (skipped)
/etc/letsencrypt/live/kibana.allenintech.com/fullchain.pem expires on 2023-03-14 (skipped)
/etc/letsencrypt/live/nextcloud.allenintech.com-0001/fullchain.pem expires on 2023-01-31 (skipped)
/etc/letsencrypt/live/www.kibana.allenintech.com/fullchain.pem expires on 2023-03-13 (skipped)
Congratulations, all renewals succeeded:
systemctl list-timers is voluminous.
I see under UNIT snap.certbot.renew.timer
I see under ACTIVATES snap.certbot.renew.service
We can help you fix the symlinks. But we are going to have to step back and re-evaluate your configuration.
There are priorities and we need to all be on the same page.
From what I have seen your cron is ready to ask for a new cert. But it wont do it until it is time to renew.
Let's re-visit this in the morning, my friend.
