My domain is: n/a
I ran this command: see below
It produced this output: none
My web server is (include version): Apache 2.2.15
The operating system my web server runs on is (include version): CenOS 6.10
or certbot-auto --version
if you’re using Certbot): certbot 0.39.0
I installed several LE certificates which are working fine. I then tried to automate the renewal process using the recommended line on https://certbot.eff.org/lets-encrypt/centos6-apache which suggests adding a cronjob using the following statement
echo "0 0,12 * * * root python -c 'import random; import time; time.sleep(random.random() * 3600)' && /usr/local/bin/certbot-auto renew" | sudo tee -a /etc/crontab > /dev/null
Although certbot-auto renew from the command line does what it is supposed to do, the above statement created the cron job in /etc/crontab although the latter part | sudo tee -a /etc/crontab > /dev/null
is missing
I also have the following cron directories in /etc (and one cronjob in /var/spool/cron)
cron.d
cron.daily
cron.hourly
cron.monthly and
cron.weekly
Except for the latter two that are empty, they contain named cron job files
the crontab -l command gives me only the cron job listed in the /var/spool/cron directory.
0,5,10,15,20,25,30,35,40,45,50,55 * * * * /etc/webmin/status/monitor.pl
My questions are:
- Why does crontab -l not list the other cron jobs in cron.* directories and /etc/crontab?
- Why so many places for cron jobs
- Am I also supposed to create a file with the recommended statement in the cron.daily directory or the /var/spool/cron directory?
- Is the name of the cron job of any consequence?
Thanks
