Started issuing a wildcard SSL/TLS certificate from Let's Encrypt for the domain visyon-hub.com.
Please wait while Plesk finishes adding a DNS record with the following parameters:
Record type: TXT
Domain name: _acme-challenge .visyon-hub.com
Record: R0olWlLEYTml59g--e3HMEvy-Of8Q3JhFBe-zz8NJjM
To terminate and delete the existing certificate request, click "Cancel".
That may also now be outdated.
You need to run the cert request and it will show you a new TXT record.
pause there and add the record to your DNS
then confirm the record shows in both DNS servers (ns59 and ns60)
then continue the cert request
I reissue the certificate, then verify and add the DNS registry in goddady:
Record type: TXT
Record: -RFxkwOjLq_arWeRoA91F9KvLRoBXlPzUQlGjy_H37U
