Could not connect to .well-known
https://www.beulenrechner.de/.well-known/acme-challenge/letsencrypt
Your non-HTTPS website redirects to the HTTPS variant of the same website. But the HTTPS site is ā€œā€ā€œprotectedā€"" by a self-signed certificate.
While a redirect isn’t going to be a problem (it shouldn’t anyway), I think a redirect to an invalid TLS secured site isn’t going to work.
You could try to disable redirecting for the /.well-known/acme-challenge/ location.
This here is the snippet , which necessary must be entered in the Apache directives sections. As I said I used ispconfig.
The problem must be caused by a change in the LE clients recently.
# Verzeichnis für Let's Encrypt Webroot Methode
<IfModule mod_headers.c>
    <LocationMatch "/.well-known/acme-challenge/*">
        Header set Content-Type "text/plain"
    </LocationMatch>
</IfModule>
# Immer Umleiten auf https
<IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteCond %{HTTPS} off
    RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
</IfModule>
@Osiris: Self-signed or expired certificates are generally fine when used with http-01 - the validation is based on the IP address returned by DNS and something that IP address serves in cleartext without authentication, so if that connection is compromised, it’s game over anyway.
I’ve seen some issues where boulder was unable to connect because of a self-signed SHA-1 certificate, so it could still be related to the certificate, although this one isn’t SHA-1. I tried debugging this using a local CA server (boulder), but it’s succeeding (as in: I’m getting an expected HTTP 404, and not a ā€œgeneralā€ connection error). Could be a configuration difference between what I’m running and the production boulder instance, though.
@MikeFrizz: Here is one more idea on how to avoid redirecting to HTTPS for .well-known/acme-challenge. Add the following line:
RewriteCond %{REQUEST_URI} !^/\.well\-known/acme\-challenge/
right before
If Let’s Encrypt is still reporting a connection error with your next run, it’s not related to your SSL configuration, but rather some network issue.
You did it. Thx a lot.
