Hi, I have several certificates on my server, almost all of them are correctly renewed, but I have a problem with one. Error says:
Attempting to renew cert from /etc/letsencrypt/renewal/control.delosdigital.it.conf produced an unexpected error: Failed authorization procedure. redazione.delosdigital.it (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://redazione.delosdigital.it.well-known/acme-challenge/AxBemnBGtL7qzfGUIe7ijVo7srLehD3Ev2gZCRB4z8M: Error getting validation data. Skipping.
Looks like he can’t get the challenge document. As you may note, there is no / between the domain and .well-know/etc. I guess probably there is some error somewhere in my configurations, but can’t find where. Apache configuration is right (domain works); renew conf looks like the others:
[[webroot_map]]
retro.delosstore.it = /var/www/delosbooks/delosstore.it/www./retro
control.delosdigital.it = /var/www/delosbooks/delosdigital.it/control.
I forgot to say: the well-known directory has bee created correctly. He just can’t get it back via http
Where can I try to look?
Thanks
S*
