gwp.linuxhotel.de
desktop.lab.linuxhotel.de
pad.lab.linuxhotel.de
pad.linuxhotel.de
systemctl start dehydrated.service
( calls dehydrated -c and then reloads apache config )
Times are Europe/Berlin timezone
Feb 27 12:40:06 hostname dehydrated[13893]: ERROR: Challenge is invalid! (returned: invalid) (result: ["type"] "http-01"
Feb 27 12:40:06 hostname dehydrated[13893]: ["url"] "https://acme-v02.api.letsencrypt.org/acme/chall/545759006/482241701675/Vv8qCw"
Feb 27 12:40:06 hostname dehydrated[13893]: ["status"] "invalid"
Feb 27 12:40:06 hostname dehydrated[13893]: ["validated"] "2025-02-27T11:40:02Z"
Feb 27 12:40:06 hostname dehydrated[13893]: ["error","type"] "urn:ietf:params:acme:error:connection"
Feb 27 12:40:06 hostname dehydrated[13893]: ["error","detail"] "185.232.103.116: Fetching https://desktop.lab.linuxhotel.de/.well-known/acme-challenge/Ecp0rh24GiRng6xVzl4utmDveQb5PRUqsoS
4wEfcwCU: Connection refused"
Feb 27 12:40:06 hostname dehydrated[13893]: ["error","status"] 400
Feb 27 12:40:06 hostname dehydrated[13893]: ["error"] {"type":"urn:ietf:params:acme:error:connection","detail":"185.232.103.116: Fetching https://desktop.lab.linuxhotel.de/.well-known/ac
me-challenge/Ecp0rh24GiRng6xVzl4utmDveQb5PRUqsoS4wEfcwCU: Connection refused","status":400}
Latest Apache on Debian Bookworm
Debian
Self
Yes
No
Dehydrated version: 0.7.0
What I did:
Check if the $host/.well-known/acme-challenge/whatever is served properly from multiple network perspectives =
(Other own IP, Deutsche Telekom DSL, Vodafone DSL, Mullvad, Hostsharing, Hetzner) Existing files get served, nonexisting get 404. -
Check that files created by the acme script are accessible by the webserver
Check that the firewall does not block incoming TCP 443,80
Check that nothing specialcases the LE src ips trying to request
Check that upstream network does not block LE from reaching us
(But Email and other stuff works) -
Check that LE does not block us
This is this post.
Our relevant IPs are:
Curl egress 185.232.103.115
A 185.232.103.116
AAAA 2a0f:6480:1::2/64
