I’m trying to get a certificate installed in my HAProxy server for the domain vpl.dynu.net but I’m getting a connection error:
~$ sudo certbot certonly --standalone --preferred-challenges http --http-01-port 80 -d vpl.dynu.net -
d www.vpl.dynu.net
http-01 challenge for vpl.dynu.net
http-01 challenge for www.vpl.dynu.net
Failed authorization procedure. vpl.dynu.net (http-01): urn:acme:error:connection :: The server
could not connect to the client to verify the domain :: Fetching http://vpl.dynu.net/.well-known/acme-
challenge/Kcr_gIz-GfAvaq6ZxSYIPcIe7hGmst9VpXoGP3P2hnc: Timeout
Domain: vpl.dynu.net
Type: connection
Detail: Fetching
http://vpl.dynu.net/.well-known/acme-challenge/Kcr_gIz-GfAvaq6ZxSYIPcIe7hGmst9VpXoGP3P2hnc:
Timeout
I performed a capture and can see the SYN coming in but my server doesn’t respond with the SYN-ACK.
This might be a red herring but I ran netstat a few times during the cert attempts and found that IPv6 is who listens to port 80 and not IPv4.
BEFORE running certbot:
~$ netstat -lputn
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
DURING certbot:
~$ netstat -lputn
tcp6 0 0 :::80 :::* LISTEN -
Should also include IPv4.
And since we see "addressUsed": "186.15.1.69" in the logs, then we must ensure IPv4 is being used.
I would try connecting to http://vpl.dynu.net/
while certbot is running to make sure it is passing through HAProxy correctly.
or
telnet 127.0.0.1 80
The thing is, I’m installing the cert inside the server running HAProxy. When I do this, I have to stop the HAProxy service so that certbot can bind/listen to port 80.
If you are running haproxy then you will want it to proxy to the Let’s Encrypt client you are using, probably with something like an ACL in your frontends:
acl letsencrypt-acl path_beg /.well-known/acme-challenge/
use_backend letsencrypt-backend if letsencrypt-acl
and add a backend:
server letsencrypt 127.0.0.1:54321
and get certbot to serve the challenge via :54321, whichever way that is done.
Could you describe how you are wanting to run haproxy / certbot? I'm having a hard time wrapping my head around it.
In your original post you are using certbot standalone via :80.
If you are intending to run haproxy on :80, the only way to successfully run certbot in standalone mode would be to run its listener on an alternate port and proxy to the certbot listener via an ACL in HAProxy.
That article only does stop+certbot+start to bootstrap the initial Let's Encrypt certificate, which is where you seem to be stuck. I would argue this step is unnecessary/overcomplicating things but we'll stick to it.
For automatic renewal, the article runs Certbot on :54321 and is proxied to by an ACL in HAProxy.
Back to your problem, we see in your logs:
2017-11-21 20:12:26,033:DEBUG:acme.standalone:Failed to bind to :80 using IPv4
So, this is an environmental issue, something like:
Something is already bound on :80 when you try to run certbot (which you've already tried to exclude, but could you please run it as root: sudo ss -tlp)
You don't have the capability to bind to :80, which would certainly be odd as root (get more details by getting netcat/nc and running sudo nc -vvv -l -p80)
Yes. Similar to what I said there, not explicitly binding on IPv4 probably isn’t the problem as most Linux systems redirect IPv4 traffic to an IPv6 port by default and Certbot tries to bind using IPv4 on the systems that don’t.
If you want though, you can use --http-01-address to set the address Certbot should listen on. You can give this flag either an IPv4 or an IPv6 interface. For example, you can use --http-01-address 0 or --http-01-address 0.0.0.0 to have Certbot listen using IPv4 on all interfaces.
