CodeIT Apache problem
Hi, I updated Apache with codeIT distribution and I am unable now to issue certificates since certbot cannot understand Apache configuration.
I seem the issue is the same as in The apache plugin is not working since the command
apachectl -t -D DUMP_RUN_CFG
is not supported, but from that thread the problem should have been solved last September…
www.lightpoint.info
certbot --apache
The apache plugin is not working; there may be problems with your existing configuration. The error was: MisconfigurationError('Apache is unable to check whether or not the module is loaded because Apache is misconfigured.',)
Apache, 2.4.43, latest codeit distribution
Centos 7.7.1908
cerbot --version
1.3.0
Thanks a lot
Giuse
2 posts were merged into an existing topic: The apache plugin is not working
A post was merged into an existing topic: The apache plugin is not working
