Hello! First let me say thanks to the letsencrypt community for creating such a wonderful way to acquire HTTPs!
I just had a slight issue using cerbot that I was curious if someone could assist me with. When running
cerbot --apache
I select the domains I want HTTPS added too, however certbot gives the following error:
Failed authorization procedure. jira.metamesh.org (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: networking error looking up A for jira.metamesh.org
Domain: jira.metamesh.org
Type: connection
Detail: DNS problem: networking error looking up A for
jira.metamesh.org
I’m aware that this issue has been posted on the forums before, but in each case it was either a firewall issue or DNS issue. I can say with absolute 100% certainty that the issue is not with my server, nor my DNS. My A record for “jira.metamesh.org” is definitely pointing too our IP, 96.89.42.101
I’m honestly confused, as I’ve installed two certificates before this site on the same exact server with no trouble. Any help would be greatly appreciated!!
EDIT
It seems all users are having this problem at this time. As someone else suggested, using the “–staging” option with certbot solved the issue for me.
There was an issue that has been resolved. It should be noted that the --staging option tests against the Let’s Encrypt staging CA and issues a certificate that is not trusted in browsers. It is a great way to test to make sure it is not a client issue on your side but an issue with the Let’s Encrypt service.
You should now run certbot without the --staging option to obtain a valid certificate from the trusted CA.
+ Responding to challenge for lucke.cba.si...
ERROR: Challenge is invalid! (returned: invalid) (result: {
"type": "http-01",
"status": "invalid",
"error": {
"type": "urn:acme:error:connection",
"detail": "DNS problem: networking error looking up A for lucke.cba.si",
"status": 400
DNS looks good:
$ host lucke.cba.si 8.8.8.8
Using domain server:
Address: 8.8.8.8#53
Aliases:
lucke.cba.si is an alias for us.dev.cba.si.
us.dev.cba.si has address 170.130.139.8
$ host lucke.cba.si 208.67.222.222
Address: 208.67.222.222#53
Aliases:
