www.ensignathletics.org
sudo certbot --nginx
blank to select all options shown (Enter ‘c’ to cancel):
http-01 challenge for ensignahtletics.org
Waiting for verification…
Failed authorization procedure. ensignahtletics.org (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for ensignahtletics.org - check that a DNS record exists for this domain
Domain: ensignahtletics.org
Type: None
Detail: DNS problem: NXDOMAIN looking up A for ensignahtletics.org
I dont know
or certbot-auto --version
if you’re using Certbot):
I am new to this and I have only certified one other website. that website had a subdoman but this one isn’t suppose to it should just be www.ensignathletics.org I am not sure if this is the problem or if something else is. Any help is great thank you
