Nope does not work tried it with restart…Should I delete everything and generate this certs again?
I think that needs to be included - it is trapped in the Directory block.
Thanks it works now! Can I delete the RewriteEngine On inside directory?
Probably not.
But you can easily test it both ways.
I better leave it as it is now! Anyway thank you so much made my day!!
All’s well that ends well.
Cheers!
