Changing authenticator from Manual to nginx
Hey Everyone!
I originally installed certs on a particular system with certbot in manual mode. Situations have changed with that server and I’d like to do renewals with the nginx plugin. I’m not sure what the best practice is for this. Can I run certbot commands to make the needed changes? I can’t seem to find the best instructions if so.
I’m willing to do .conf file changes, but I’m curious if I can do something like revoke the current certificates, then run $ sudo certbot --nginx to get a new certificate? Are there any potential issues with this approach?
Thank you very much!
-Ken
My domain is: language.cs.ucdavis.edu
My web server is (include version): nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.4 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Do not revoke certificates.
I guess you can just do certbot renew --nginx --dry-run and see what happens. :wink:
I’ve tried some variations on that idea, but here’s what happens. I put a configuration file I thought might be helpful, below.
Thanks for responding!
$ sudo certbot renew --nginx --dry-run
Processing /etc/letsencrypt/renewal/language.cs.ucdavis.edu.conf
Attempting to renew cert (language.cs.ucdavis.edu) from /etc/letsencrypt/renewal/language.cs.ucdavis.edu.conf produced an unexpected error: None of the preferred challenges are supported by the selected plugin. Skipping.
/etc/letsencrypt/live/language.cs.ucdavis.edu/fullchain.pem (failure)
$ cat /etc/letsencrypt/renewal/language.cs.ucdavis.edu.conf
renew_before_expiry = 30 days
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/language.cs.ucdavis.edu
cert = /etc/letsencrypt/live/language.cs.ucdavis.edu/cert.pem
privkey = /etc/letsencrypt/live/language.cs.ucdavis.edu/privkey.pem
chain = /etc/letsencrypt/live/language.cs.ucdavis.edu/chain.pem
fullchain = /etc/letsencrypt/live/language.cs.ucdavis.edu/fullchain.pem
[renewalparams]
account = xxxxxxx REVOKED xxxxxxxx
pref_challs = dns-01,
authenticator = manual
manual_public_ip_logging_ok = True
well, the nginx plugin only supports http-01. maybe add --preferred-challenges=http too? (I don't know if this option will be understood.)
I don't know what that means... perhaps "REDACTED" ???
If you think they are causing you any trouble, you could just delete those lines and they will "grow back" on the next successful renewal/issuance.
Sorry, yes I had REVOKED on the mind, that should be REDACTED :slight_smile:
