Challenge Faild for domain
My domain is: www.lightmedia.club lightmedia.club
I ran this command: sudo certbot --nginx
1: lightmedia.club
2: ask.lightmedia.club
3: www.ask.lightmedia.club
4: deluge.lightmedia.club
5: www.deluge.lightmedia.club
6: vm.lightmedia.club
7: www.lightmedia.club
blank to select all options shown (Enter ‘c’ to cancel):
http-01 challenge for deluge.lightmedia.club
http-01 challenge for lightmedia.club
http-01 challenge for www.ask.lightmedia.club
http-01 challenge for www.deluge.lightmedia.club
http-01 challenge for www.lightmedia.club
Waiting for verification…
Challenge failed for domain lightmedia.club
Challenge failed for domain www.lightmedia.club
nginx version: nginx/1.16.1 (Ubuntu)
built with OpenSSL 1.1.1c 28 May 2019
TLS SNI support enabled
NAME=“Ubuntu”
VERSION=“19.10 (Eoan Ermine)”
Domain is held by Ionos otherwise self hosted
certbot 0.36.0
I was able to get self signed cert on the site. I am really not sure what is causing my challenge fail since the rest of my sub-domains are working. i was able to get them to pass the challenge by redirecting the cname of each one to my duckdns. Ionos will not allow cname on top level domain so i have resorted to Redirect (Frame) http://xzzy.duckdns.org.
Hi @killerherts
there is a check of your domain, ~~one hour old - https://check-your-website.server-daten.de/?q=lightmedia.club
You have ipv4 and ipv6:
lightmedia.club A 74.208.236.4 Kansas City/Missouri/United States (US) - 1&1 Internet SE Hostname: 74-208-236-4.elastic-ssl.ui-r.com yes 1 0
AAAA 2607:f1c0:100f:f000::2ab Kansas City/Missouri/United States (US) - 1&1 Internet SE yes
www.lightmedia.club A 74.208.236.4 Kansas City/Missouri/United States (US) - 1&1 Internet SE Hostname: 74-208-236-4.elastic-ssl.ui-r.com yes 1 0
Both send the answer http status 204 - No Content.
You can't create a Letsencrypt certificate
with such a frame redirect.
So if Ionos doesn't allow a CNAME, you can't create a certificate if you have a dynamic ip address.
You may create a CNAME with the www subdomain, then use only the www version.
Ok that makes sense, if I adjust the name servers to be xzzy.duckdns.org and kjhh.duckdns.org it should then point to the correct spot for the top level domain and then nginx will handle the request according to the conf
