Certificates fail to renew (used to work fine)
My domain is: msuacquisition.org, www.msuacquisition.org jatos.msuacquisition.org
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/msuacquisition.org.conf
Simulating renewal of an existing certificate for msuacquisition.org and 2 more domains
  Domain: msuacquisition.org
  Type:   unauthorized
  Detail: 185.199.111.153: Invalid response from http://msuacquisition.org/.well-known/acme-challenge/RMPEK0PWYpbSTFVnqUoAhCBHQi-cZMpZVQIilElhKys: 404
  Domain: www.msuacquisition.org
  Type:   unauthorized
  Detail: 2606:50c0:8003::153: Invalid response from http://www.msuacquisition.org/.well-known/acme-challenge/YWKnJo5J1E06cBz4boYU9xiiAm0cfod9HoaS1p7cFu4: 404
Failed to renew certificate msuacquisition.org with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
  /etc/letsencrypt/live/msuacquisition.org/fullchain.pem (failure)
My web server is (include version): Apache/2.4.41 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04.6 LTS
My hosting provider, if applicable, is: Amazon AWS EC2
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): AWS?
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 3.0.1
Of those 3 domain names only your jatos subdomain points to an Apache server hosted at EC2. Is this the only domain you need a cert for?
Because your apex domain and www subdomain have valid certs and are using Varnish CDN and GitHub. This is very different than direct to Apache. Looks like you might have setup Github and Varnish in late August based on your cert history.
Also, your DNS for your apex domain is different than for your www subdomain. Your apex domain has 4 IPv4 addresses. Your www subdomain has a CNAME to msu-language-acquisition-lab.github.io. which has 4 IPv4 and 4 IPv6 addresses. These two domain don't technically require identical IP address lists but usually that's what is done.
Thanks! Yes, the jatos subdomain is probably the only domain I need the cert for. Indeed I did set up the lab web page in August and before that the www and apex domains were running on the EC2 apache server. So how do I get certbot to just get the cert for the jatos subdomain and remove the www and apex domain?
Never mind, I found what I needed.
certbot certonly --cert-name msuacquisition.org -d jatos.msuacquisition.org
does the trick and removes the www and apex domains from the cert.
Thanks again for the help.
