My domain is: mps.colourworker.com
I ran this command: sudo certbot certonly --dns-route53 -d mps.colourworker.com
An RSA certificate named mps.colourworker.com already exists. Do you want to
update its key type to ECDSA?
(U)pdate key type/(K)eep existing key type: K
(ref: /etc/letsencrypt/renewal/mps.colourworker.com.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for mps.colourworker.com
Certificate is saved at: /etc/letsencrypt/live/mps.colourworker.com/fullchain.pem
Key is saved at: /etc/letsencrypt/live/mps.colourworker.com/privkey.pem
This certificate expires on 2024-07-30.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
- Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
- Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
My web server is (include version): Apache/2.4.29 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.4 LTS
My hosting provider, if applicable, is: AWS
or certbot-auto --version
if you're using Certbot): certbot 2.10.0
I recently updated the certificate to mps.colourworker.com using certbot and at about the same time our app running on versions of Android around SDK 24 fails with "javax.net.ssl.SSLHandshakeException: Handshake failed". However the app running on SDK 30 works perfectly.
Kind regards,
Miguel
