Certificate verification errors when using curl
My domain is: www.forpilots.com
I ran this command: curl https://www.forpilots.com
curl: (60) server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a “bundle”
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn’t adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you’d like to turn off curl’s verification of the certificate, use
the -k (or --insecure) option.
My web server is (include version): Apache/2.2.15
The operating system my web server runs on is (include version): Centos 6.7
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.39.0
Notes: The https:// url works fine when using a windows browser, but experiences the verification issue only when using curl under linux (specifically, from Ubuntu-16.04)
You are not sending a full certificate chain from your webserver. This will have mixed results in different browser/OS combos, as you have observed.
Since you are using Apache 2.2, you will want to do something like:
SSLCertificateChainFile /etc/letsencrypt/live/forpilots.com/chain.pem
and restarting Apache. The exact subdirectory inside live/ may be slightly different based on how your certificate is named.
Thanks, that worked perfectly!
