I usually do that for third-party situations where the hosting provider and the domain registrar are not the same. But, now from this experience, I will certainly keep that as an option as well.
By the way, I ran the script now and it was successful. I guess adding the wild card option manually before might have helped now.
root@jitsi:####### ./inst*
This script will:
Need a working DNS record pointing to this machine(for domain aioexplorer.com)
Install additional dependencies in order to request Letâs Encrypt certificate
If running with jetty serving web content, will stop Jitsi Videobridge
Configure and reload nginx or apache2, whichever is used
Configure the coturn server to use Letâs Encrypt certificate and add required deploy hooks
Add command in weekly cron job to renew certificates regularly
You need to agree to the ACME serverâs Subscriber Agreement (https://letsencrypt.org/documents/LE-SA-v1.1.1-August-1-2016.pdf)
by providing an email address for important account notifications
Running deploy-hook command: /etc/letsencrypt/renewal-hooks/deploy/0000-coturn-certbot-deploy.sh
Output from deploy-hook command 0000-coturn-certbot-deploy.sh:
Configuring turnserver
Congratulations! Your certificate and chain have been saved at:
/path/to/the/folder/fullchain.pem
/path/to/folder/privkey.pem
Your cert will expire on 2020-11-10. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
âcertbot renewâ
By the way, the REASON that it worked is because you already satisfied the manual DNS challenges so you donât need to reverify for 30 days to get new certs. Youâll need to complete the DNS challenges AGAIN when you renew (unless you can find an automated way to create/destroy them through certbotâs âhooksâ).
Iâm also getting this after I clear my cache and go directly to your non-www. Itâs at least the same certificate (but you may have multiple copies of this same cert under different configurations).
It won't matter, default is just a name to nginx. What matters is the order in which those files get included, and whether any of them contain a listen something default_server; directive.
This might be due to the manual installation leading to different options and the non-www might be still deploying to the default site.
I have set a redirect from @ to www, which redirects as you confirmed. However, the non-www site still needs to be resolved. But, we have come a long way and the good thing is the site is functional and the SSL is working for at least the fqdn. For a while today, neither was working.
One thought: What would happen if I were to add aioexplorer.com to the server name list and then run the script again? Would that address the issue with the non-www site?
Manual DNS-based certonly wildcard cert using certbot just to get the cert issued.
Run the built-in jitsi Letâs Encrypt script that reissues the same cert with NO challenges (due to previous DNS verification) AND correctly installs the cert.
I'm honestly not sure why there are two different sets of content configured. There should be only one content with a permanent (301) redirect from @ to www (or vice versa).
It looks like I have fixed the issue for the non-www site as well by adding the @ domain to the server name list.
Jonathan, yes. It was a hybrid solution and the inclusion of all relevant domain names part of the server name list appears to capture the SSL for all related domains.
Please record your expiration somewhere as obviously this wonât manually renew. You could try to renew (just generate a new cert) in like 45 days just to ensure things are stable.
I was thinking about it, and I wonder whether I would need to generate the certificates manually, now that the wild card issue has been rectified. I think the script should work from next time onwards. I will confirm when I am up for renewal next time.
The script doesnât support DNS challenges, which are required for wildcard certs. Unless you somehow configure a DNS authentication hook for creating/destroying the TXT records, youâll need to manually renew with new TXT records.
