Hi Guys, I got a server running nginx as a webserver and using let's encrypt to provide the SSL certificate. I just noticed that my site is no longer getting a valid certificate so I started to investigate. Could not find the error so i decided to ask the help of this community.
My domain is: samartis.de
Processing /etc/letsencrypt/renewal/samartis.de.conf
http-01 challenge for samartis.de
http-01 challenge for www.samartis.de
nginx: [warn] conflicting server name "www.samartis.de" on 0.0.0.0:443, ignored
nginx: [warn] conflicting server name "samartis.de" on 0.0.0.0:443, ignored
nginx: [warn] conflicting server name "www.samartis.de" on [::]:443, ignored
nginx: [warn] conflicting server name "samartis.de" on [::]:443, ignored
nginx: [warn] conflicting server name "samartis.de" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name "www.samartis.de" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name "samartis.de" on [::]:80, ignored
nginx: [warn] conflicting server name "www.samartis.de" on [::]:80, ignored
Challenge failed for domain samartis.de
Challenge failed for domain www.samartis.de
Attempting to renew cert (samartis.de) from /etc/letsencrypt/renewal/samartis.de .conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/samartis.de/fullchain.pem (failure)
Domain: samartis.de
Type: connection
Detail: 89.58.37.59: Fetching
https://www.samartis.de/.well-known/acme-challenge/47nLhmvO_DXaZAdaFskqkerlCW sIfWQGgXlZYd8O8dw:
Timeout during connect (likely firewall problem)Domain: www.samartis.de
Type: connection
https://www.samartis.de/.well-known/acme-challenge/Yr-4r5515mdCDEq08GbGHr3k5c LqQsfjyqeoH12h81Y:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
My web server is (include version): nginx 1.18.0
The operating system my web server runs on is (include version): ubuntu 20.04.4 LTS
My hosting provider, if applicable, is: netcup GmbH (Germany)
or certbot-auto --version
if you're using Certbot): certbot 0.40.0
UFW Firewall status: Status: active
To Action From
Nginx Full ALLOW Anywhere
22/tcp LIMIT Anywhere
OpenSSH ALLOW Anywhere
80 ALLOW Anywhere
443 ALLOW Anywhere
Nginx Full (v6) ALLOW Anywhere (v6)
22/tcp (v6) LIMIT Anywhere (v6)
OpenSSH (v6) ALLOW Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
I am redirecting http traffic to https via the following nginx config line:
listen 80;
listen [::]:80;
server_name samartis.de www.samartis.de;
return 301 https://www.samartis.de$request_uri;
Could that be the root cause for my problem?
