Any thoughts?
Way too many...
About this:
Make sure you added a <directory> section that allows everyone access to the newly created path.
Ok the test file works now, but I think I need to redo the certificate for webmin.
Slow and steady progress.
Retry the --dry-run
I did and it still failed with the below error
Processing /etc/letsencrypt/renewal/bearclawats.com.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
Simulating renewal of an existing certificate for bearclawats.com and www.bearclawats.com
http-01 challenge for bearclawats.com
http-01 challenge for www.bearclawats.com
new certificate deployed with reload of apache server; fullchain is
/etc/letsencrypt/live/bearclawats.com/fullchain.pem
Processing /etc/letsencrypt/renewal/prod.bearclaw.io.conf
Simulating renewal of an existing certificate for prod.bearclaw.io
http-01 challenge for prod.bearclaw.io
Using the webroot path /var/lib/letsencrypt for all unmatched domains.
Challenge failed for domain prod.bearclaw.io
Failed to renew certificate prod.bearclaw.io with error: Some challenges have failed.
The following simulated renewals succeeded:
/etc/letsencrypt/live/bearclawats.com/fullchain.pem (success)
The following simulated renewals failed:
/etc/letsencrypt/live/prod.bearclaw.io/fullchain.pem (failure)
Domain: prod.bearclaw.io
Detail: Invalid response from
http://prod.bearclaw.io/.well-known/acme-challenge/7srmlufeGn3ZAwKvBuY6SIs6XbvfWgeLBeHfpg92usI
[]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML
2.0//EN\">\n<html><head>\n<title>404 Not
Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
contain(s) the right IP address.```
Did you use --webroot to obtain the cert?
Please show this file:
no webmin has a menu in the config to obtain the cert.
version = 1.11.0
archive_dir = /etc/letsencrypt/archive/prod.bearclaw.io
cert = /etc/letsencrypt/live/prod.bearclaw.io/cert.pem
privkey = /etc/letsencrypt/live/prod.bearclaw.io/privkey.pem
chain = /etc/letsencrypt/live/prod.bearclaw.io/chain.pem
fullchain = /etc/letsencrypt/live/prod.bearclaw.io/fullchain.pem
[renewalparams]
account = 71a50be4990a0dc15bcc7672118694cd
manual_public_ip_logging_ok = None
authenticator = webroot
rsa_key_size = 2048
webroot_path = /var/lib/letsencrypt,
[[webroot_map]]
Remove the last two lines:
and also remove the line:
and retry the --dry-run
Here is the error I received.
Renewal configuration file /etc/letsencrypt/renewal/prod.bearclaw.io.conf does not specify an authenticator. Skipping.
Lovely...
Please show the file:
version = 1.11.0
[renewalparams]
# authenticator = webroot
rsa_key_size = 2048
# webroot_path = /var/lib/letsencrypt,
# [[webroot_map]]
That was the prod renewal file.
Please show the other renewal file.
[and when I said remove I meant remove - not rem out - certbot will put back whatever it needs]
oh sorry here you go.
version = 1.11.0
archive_dir = /etc/letsencrypt/archive/bearclawats.com
cert = /etc/letsencrypt/live/bearclawats.com/cert.pem
privkey = /etc/letsencrypt/live/bearclawats.com/privkey.pem
chain = /etc/letsencrypt/live/bearclawats.com/chain.pem
fullchain = /etc/letsencrypt/live/bearclawats.com/fullchain.pem
[renewalparams]
authenticator = apache
installer = apache
That is what we need in the other file.
Anywhere below "[renewalparams]"
I changed the authenticator that I commented out and it worked.
What worked [exactly]?
OK I see:
curl http://prod.bearclaw.io/.well-known/acme-challenge/test-file-1234
test file
Retry the --dry-run
changing the authenticator from webroot to apache in the prod.bearclaw.io.conf file and then doing an httpd reload
I had already fixed the forbidden issue by adding the directory entry, but then the other error cleared by changing the authenticator like you suggested.
So did the --dry-run succeed?
Are all your certs up-to-date?
yes, that is what I meant by it worked sorry for the lack of clarity it's late where I am.
