Certificate renewal is failing with missing /
Haha I bet it's just as late (or later) where I am - LOL
Cheers from Miami :beers:
#FreeCuba
I live in FL, but visiting my family up north.
Cool thanks for your help, I will do the same tweaks to the other 2 servers.
It was my pleasure :slight_smile:
Have a blessed evening.
It's past 3a.m. here, but I know what you mean.
Likewise to you too my friend :slight_smile:
I have a question in regards to a server I have that houses multiple URL's under different DocumentRoot's I will still need the <virtualhost *:80> with the ServerName entry for each URL, but then use the config above for the letsencrypt stuff?
I'm having a hard time understanding. How do you mean "multiple URLs"? Are those multiple URLS with the same hostname but different paths? Or are all those URLs also all separate hostnames?
Because as far as I know, every distinct DocumentRoot would be for a separate hostname and that would indeed require a separate VirtualHost directive.
Sorry about that I meant 2 vhosts with 2 different domains, 1 lives in the main DocumentRoot and the other lives in a different DocumentRoot.
My question is would I specify the letsencrypt config that @rg305 assisted me with once or for each vhost entry?
This thread has 88 posts already, it is probably wise to specificy exactly what configuration you're refering to, so we don't misunderstand each other.
If you don't need anything specifically individualized to any domain, you can catch all HTTP requests and deal with them in one fell swoop using only one HTTP vhost config (as default).
If you don't plan on building the HTTPS vhost config, then you will need an HTTP vhost config for certbot to work from and may need one for each domain.
Whether using one HTTP vhost config, or many, they can all use the same challenge path.
I hope that was clear enough for you to proceed.
If you have any questions, just ask them.
This is the config I was referring to.
<VirtualHost *:80>
  DocumentRoot /some/unique/path
  <LocationMatch "^/(?!\.well-known)">
    #send all other requests to HTTPS
    RewriteEngine On
    RewriteCond %{HTTPS} !=on
    RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1
  </LocationMatch>
</VirtualHost>
Well, that looks like quite a complicated piece of configuration. Not sure why it's there, but if somehow your Apache configuration requires it, it's probably also needed in other VirtualHosts?
I would like to keep the 2 sites individualized and the https config for letsencrypt already exists for both and just for reference I am experiencing the same issue that you helped me with early this morning. @rg305
Using that single HTTP vhost config, all HTTP challenge request will go to "/some/unique/path" regardless of the domain requested.
All other HTTP requests will be forwarded to HTTPS.
This, although simple, will not provide enough resource to allow certbot to configure the HTTPS vhost config for you.
So, you must not use an installer with it (Like: -i apache or -i nginx) and you will have to make the HTTPS vhost config yourself (just copy a working config and change the server name, document root, and cert files),
Be very clear here.
Do you also need separate HTTP sites or just the separate HTTPS sites?
HTTPS are already individualized.
Both sites are https with the same http to https redirect that is now erroring on renewal, so I was going to duplicate the same config with my other 2 servers, but when I remembered the second server was hosting 2 url's I wasn't sure if the one config would work for both or I needed to add it to each vhost entry.
Yes this server is setup the same as the other one just with an extra vhost entry.
Please show the error and the associated renewal.conf file.
[have you learned nothing - LOL]
yes https is already individualized as I mentioned yesterday evening it was working and then I started receiving the same error.
   Domain: jobboard.bearclaw.io
   Type:   connection
   Detail: Fetching
   https://careerportal.nlr.careers.well-known/acme-challenge/vzHnbexKuUG-KUdPoVU7smD4OFQQqROnFyuCXYcqQI8:
   Invalid host in redirect target
   "careerportal.nlr.careers.well-known". Check webserver config for
   missing '/' in redirect target.
Here is the httpd.conf
<VirtualHost *:80>
    ServerName careerportal.nlr.careers
    ServerAlias careerportal.nlr.careers
    Redirect 301 / "https://careerportal.nlr.careers"
RewriteEngine on
RewriteCond %{SERVER_NAME} =careerportal.nlr.careers
</VirtualHost>
<VirtualHost *:443>
    ErrorLog /var/log/httpd/careerportal.nlr.careers-error.log
    LogLevel crit
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-agent}i\"" vh$
    LogFormat "%v %h %l %u %t \"%r\" %>s %b" vhost_common
    CustomLog /var/log/httpd/careerportal.nlr.careers-access.log "combined"
SSLCertificateFile /etc/letsencrypt/live/careerportal.nlr.careers/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/careerportal.nlr.careers/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/careerportal.nlr.careers/chain.pem
</VirtualHost>
<VirtualHost *:80>
    ServerName bearclaw.io
    DocumentRoot /var/www/html/bearclaw.io
    RedirectMatch 301 / "https://bearclaw.io"
    ServerAlias www.bearclaw.io
RewriteEngine on
RewriteCond %{SERVER_NAME} =bearclaw.io [OR]
RewriteCond %{SERVER_NAME} =www.bearclaw.io
</VirtualHost>
<VirtualHost *:443>
    DocumentRoot "/var/www/html/bearclaw.io"
    ErrorLog /var/log/httpd/bearclaw.io-error.log
LogLevel crit
    CustomLog /var/log/httpd/bearclaw.io-access.log "combined"
SSLCertificateFile /etc/letsencrypt/live/bearclaw.io/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/bearclaw.io/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/bearclaw.io/chain.pem
</VirtualHost>
In an overly dramatized story:
You enter a building looking for a specific business.
There are two attendants.
One has a sign that says: "I only speak HTTP"
The other has a sign the says: "I only speak HTTPS"
You approoach the "HTTP" guy and no sooner than you ask for the company name does he flip his sign over and it reads - "redirect all (non-challenge requests) to HTTPS".
So you then go to the "HTTPS" guy and he asks you which specific company are you looking for and then directs you to that floor/room.
When LE needs to make challenge requests the "HTTP" guy sends them all to the same path where they are all answered by the certbot that works only in that one room.
