Certificate only for site with www. (not without www. infront)
My domain is: sthlmcity.eu
I ran this command: https://sthlmcity.eu
It produced this output: "Connection not secure"
My web server is (include version): Apache/2.4.38 (Debian)
The operating system my web server runs on is (include version): Debian GNU/Linux 10 (buster)
I can login to a root shell on my machine (yes or no, or I don't know): Yes.
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): No.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
So I get SSL on www.sthlmcity.eu but not on sthlmcity.eu. I think it worked before though. Why does it not work?
When requesting or renewing a certificate ( for example, using certbot ), each individual fully-qualified domain name for the certificate should be included in the request.
e.g.: --domain sthlmcity.eu --domain www.sthlmcity.eu
Alternatively, you might switch to a dns-01 challenge and issue a wildcard certificate.
Okay. I didnt know that. So is there some command I can use in terminal to have both domain names certified?
Maybe there is a Letsencrypt guide I can follow and do it for 2 domains at once, or do it 2 times for both domains?
Edit: I followed this guide: https://certbot.eff.org/lets-encrypt/debianbuster-apache and now im stuck at:
sudo ln -s /snap/bin/certbot /usr/bin/certbot
With this result:
sudo ln -s /snap/bin/certbot /usr/bin/certbot ln: failed to create symbolic link '/usr/bin/certbot': File exists
Can you help me?
Edit 2: Okay so I moved on in the guide and now it works. Thanks for the reply Ezekiel.
