My domain is: bmc921.synology.me
I ran this command: Not sure( I use Home Assistant to renew this)
Processing /data/letsencrypt/renewal/bmc921.synology.me.conf
File “/usr/local/lib/python3.7/site-packages/certbot/renewal.py”, line 64, in _reconstitute
renewal_candidate = storage.RenewableCert(full_path, config)
File “/usr/local/lib/python3.7/site-packages/certbot/storage.py”, line 466, in init
self._check_symlinks()
File “/usr/local/lib/python3.7/site-packages/certbot/storage.py”, line 524, in _check_symlinks
“expected {0} to be a symlink”.format(link))
certbot.errors.CertStorageError: expected /data/letsencrypt/live/bmc921.synology.me/cert.pem to be a symlink
Renewal configuration file /data/letsencrypt/renewal/bmc921.synology.me.conf is broken. Skipping.
No renewals were attempted.
Additionally, the following renewal configurations were invalid:
/data/letsencrypt/renewal/bmc921.synology.me.conf (parsefail)
0 renew failure(s), 1 parse failure(s)
or certbot-auto --version
if you’re using Certbot):
