I created a clone of a live centos install, which is still running and working correctly, but the renamed clone will not recertify.As far as I can tell I have amended everything that I should, and had my ports open both on the vm, and through the university firewall. Any advice would be great!
My domain is: ctu-demo-clone.clinmed.gla.ac.uk
I ran this command: certbot-auto
It produced this output:Obtaining a new certificate
http-01 challenge for ctu-demo-clone.clinmed.gla.ac.uk
Waiting for verification…
Failed authorization procedure. ctu-demo-clone.clinmed.gla.ac.uk (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://ctu-demo-clone.clinmed.gla.ac.uk/.well-known/acme-challenge/xRjpimWFqWzWY6uQu7yXkjTztX_4KZSx-tiPgeq4D6E: Timeout during connect (likely firewall problem)
Domain: ctu-demo-clone.clinmed.gla.ac.uk
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
My web server is (include version): httpd-2.4.6-88.el7.centos.x86_64
The operating system my web server runs on is (include version): CentOS Linux release 7.6.1810 (Core)
or certbot-auto --version
if you’re using Certbot):certbot 0.29.1
