Certificate issue on one specific WiFi
Hi! I am having some issues with letsencrypt certificates, but only on one specific wifi, on latest iOS. The issue I get is that on the WiFi I get the typical message from browsers that the site is insecure, but then if I disable WiFi, access the same domain over 4G, it works. Getting back to the WiFi, it works there too. For a while, about a day.
Is there anything that I have misconfigured? Or this is a internet provider issue?
My domain is: https://bookthis.one
I ran this command: not applicable
It produced this output: not applicable
My web server is (include version): nginx/1.10.3
The operating system my web server runs on is (include version): Debian Sketch
My hosting provider, if applicable, is: not applicable
The SSL Labs test for bookthis.one shows that your server does not send the complete certificate chain — the intermediate certificate is missing.
For nginx you should specify the fullchain.pem file in ssl_certificate instead of just cert.pem.
I updated the settings based your suggestion, also done some changes to the host config, here’s the result: https://www.ssllabs.com/ssltest/analyze.html?d=bookthis.one&hideResults=on
Thank you!
