Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: journomed.com
I ran this command: followed the commands mentioned on the aws lightsail documentation
My hosting provider, if applicable, is: bitnami lightsail instance
or certbot-auto --version
if you're using Certbot):
Osiris
June 2, 2021, 5:40pm
#2
Could you please elaborate on that? Which documentation? It would be helpful if we saw all the commands you've used and what the output was.
also, tried the following comand: /opt/bitnami/bncert-tool with superuser privileges
Osiris
June 2, 2021, 5:53pm
#5
What's the output of the following command:
sudo openssl x509 -noout -text </opt/bitnami/apache2/conf/server.crt
Certificate:
Data:
Version: 1 (0x0)
Serial Number:
6e:27:83:51:f6:55:c6:d6:99:ab:5a:d1:52:ed:fe:99:c3:6b:bb:a8
Signature Algorithm: sha256WithRSAEncryption
Issuer: O = Bitnami, OU = Certificate generated at boot time, CN = www.example.com
Validity
Not Before: Feb 24 12:07:39 2021 GMT
Not After : Feb 22 12:07:39 2031 GMT
Subject: O = Bitnami, OU = Certificate generated at boot time, CN = www.example.co
m
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
RSA Public-Key: (2048 bit)
Modulus:
00:e3:87:d9:17:54:5f:c3:3f:9e:e0:26:bd:c0:ee:
eb:54:70:ad:58:c5:34:4a:91:25:9c:4f:db:84:bf:
84:e5:2c:da:eb:b7:95:93:a9:5f:0a:8a:13:94:f3:
43:0e:ff:fa:6e:f2:5e:2c:03:07:c0:ec:56:27:45:
c5:84:fd:f2:83:c9:1d:96:61:ed:34:92:04:6b:fe:
cc:61:30:6f:27:71:d9:c3:ee:8f:67:91:31:5a:f5:
47:e6:b6:55:a8:06:26:2d:aa:6b:a5:ad:76:79:39:
21:b5:d3:15:cd:bc:65:d5:a5:63:8c:8f:01:8f:4b:
4a:d1:1a:9b:c2:15:34:46:3f:44:0e:42:76:29:3c:
20:03:42:1f:f0:b1:80:33:f8:8a:09:0b:30:36:c6:
bf:7d:e0:fb:3d:4f:ae:9b:88:ad:bc:a4:bb:3d:19:
6b:c0:2b:a4:72:c1:30:f6:cb:c8:0a:fc:d9:eb:09:
c3:24:b4:99:f8:ed:c4:c9:ba:a9:a5:5a:b9:6d:56:
f1:be:47:f6:4c:71:04:78:e5:ca:f8:d3:df:72:dc:
80:26:0c:95:6a:05:00:e6:c8:05:db:35:3b:1e:05:
e3:eb:bc:12:a3:2f:1b:0d:c2:94:66:78:ae:43:e0:
0b:c2:72:b5:d7:64:7c:be:a4:62:51:85:85:c2:b9:
93:57
Exponent: 65537 (0x10001)
5c:9f:a5:41:c8:b6:d6:46:f0:61:27:9b:b6:99:7a:19:79:5a:
1c:da:cd:08:3f:05:0e:07:e9:bc:03:26:1e:b4:d3:a1:5b:c2:
2d:ee:f3:43:97:45:b0:38:ff:08:40:dd:b6:ea:b9:92:2c:af:
c7:05:aa:a9:66:c8:cd:c4:6b:55:43:e7:b9:5a:42:20:95:ea:
c6:7c:49:41:1f:04:95:3b:5b:e7:3e:9c:f3:0f:2c:44:2d:e0:
b5:4b:3b:01:5f:03:89:36:5c:31:fe:71:dd:1e:1f:0c:d1:b7:
84:e0:29:81:07:01:04:bc:32:8b:23:80:07:49:7b:cd:c9:ef:
c5:7a:29:a0:60:75:1f:33:a0:bf:d4:a7:23:6c:7a:04:12:bb:
57:54:0f:0e:f0:e6:2a:a6:91:29:53:c7:f3:57:11:06:1d:1f:
ed:f0:35:36:08:0e:9a:f7:0f:37:23:4b:b5:03:d5:2d:fb:f8:
95:87:5b:67:0a:b5:e0:8c:92:6a:4b:e9:2c:7a:93:ee:42:84:
27:54:be:e7:de:5e:af:6f:58:04:11:af:85:e0:7a:d9:07:3a:
e4:11:a8:32:55:77:05:32:6c:2e:c5:88:9b:40:46:ba:cb:d8:
00:ee:f3:9b:80:65:3c:62:6f:3d:4d:56:03:50:e7:17:50:7d:
0e:16:e8:c6
Osiris
June 2, 2021, 5:56pm
#7
It seems you haven't done step 7, or at least not in the proper way. I'm assuming you're running the newer Debian Lightsail instance and not Ubuntu?
now when I recheck my website it says certificate valid but still says Not Secure
Osiris
June 2, 2021, 6:01pm
#9
ok...let me check. Thanks!
working now. Thanks a lot!
system
closed
July 2, 2021, 6:17pm
#12
