Had you opened this thread in the Help section, you should have been provided with a questionnaire.
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
You should handle each FQDN/IP independently.
So, you handle sub.example.com as you handled example.com.
[repeating the same steps on the new server should work]
