Certificate error when using pubic IP. only works when using domain name
https://54.82.251.209
niels.operationbim.com
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Freshly installed so newest.
Image is in dutch, but it basicly says that the certificate is from the domain name and wont register for the IP one and thus won't validate https
        # SSL configuration
        root /var/www/html;
        server_name niels.operationbim.com;
                try_files $uri $uri/ =404;
        #location ~ \.php$ {
        #       include snippets/fastcgi-php.conf;
        #       # With php-fpm (or other unix sockets):
        #       fastcgi_pass unix:/run/php/php7.4-fpm.sock;
        #       # With php-cgi (or other tcp sockets):
        #       fastcgi_pass 127.0.0.1:9000;
        # concurs with nginx's one
        #location ~ /\.ht {
        #       deny all;
    ssl_certificate /etc/letsencrypt/live/niels.operationbim.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/niels.operationbim.com/privkey.pem; # managed by Certbot
#server {
#       listen 80;
#       listen [::]:80;
#       server_name niels.operationbim.com;
#       root /var/www/example.com;
#       index index.html;
#       location / {
#               try_files $uri $uri/ =404;
 #   if ($host = niels.operationbim.com) {
 #   } # managed by Certbot
        listen 80 default_server;
#    return 404; # managed by Certbot
Quite new to all this as its my first "lesson on making sites trough aws / lets encyrpt' so apologies if some data is missing
This is normal. Certificates for IP address are unusual and Let's Encrypt does not issue them currently. (They were on the roadmap but were removed at some point.)
Often multiple sites are hosted on the same IP address anyway, so it would be ambiguous what site you were accessing if you use the IP.
The only semi-free CA that currently offers certs for IP addresses that I know of is ZeroSSL and only using their web interface (or REST API perhaps), but not using their ACME API. And when using their web interface (or REST API), you'll only get 3 free certs in total per account.. So you'd need to register a new account within every 270 days (90 * 3, but less due to the fact you'd want to renew before your certificate expires).
That said, I agree with @dtaylor84 and my advice would be: just don't use the IP address to surf to your website.
Unless you have some specific need why you need to access it via ip, I think it's a good idea to redirect the requests coming to the ip directly or any unrecognized domain names to the correct domain. That way you will avoid any cert or duplicate content issues.
Add a default virtual host, something like this:
        root /var/www/html;
        server_name _;
        return 301 https://niels.operationbim.com$request_uri;
        listen 443 default_server;
        listen [::]:443 default_server;
        root /var/www/html;
        server_name _;
        include /etc/letsencrypt/options-ssl-nginx.conf;
        ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
That way if the user somehow lands on your server requesting anything other than your domain, he will be redirected to the proper domain.
Yeah, but that requester is almost certainly a bot or scanner. And, if you have multiple server blocks there is no one place to redirect to.
Instead of the return 301 statement I prefer
deny all;
or (per the nginx docs here)
return 444;
For the port 443 (HTTPS) server block I just use a self-signed cert.
