Hello,
I am trying to run certbot-auto on a Centos 6.8 machine. It is erroring out when running setup.py install for cffi with the following output:
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
Complete output from command /root/.local/share/letsencrypt/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-I0WJ85/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-A5bxqp-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cffi:
running install
running build
running build_py
creating build
creating build/lib.linux-x86_64-2.7
creating build/lib.linux-x86_64-2.7/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/recompiler.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/commontypes.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/lock.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/model.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/verifier.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/gc_weakref.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/cparser.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/__init__.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/vengine_gen.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/ffiplatform.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/api.py -> build/lib.linux-x86_64-2.7/cffi
copying cffi/_cffi_include.h -> build/lib.linux-x86_64-2.7/cffi
copying cffi/parse_c_type.h -> build/lib.linux-x86_64-2.7/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-x86_64-2.7
creating build/temp.linux-x86_64-2.7/c
/usr/bin/gcc -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -m32 -Dlinux -D__i386 -D_LINUX -D_INTEL -D_USE_SCHED -D_USE_PTHREADS -D_USE_TERMIOS -I/opt/earthworm/earthworm_svn/include -m32 -Dlinux -D__i386 -D_LINUX -D_INTEL -D_USE_SCHED -D_USE_PTHREADS -D_USE_TERMIOS -I/opt/earthworm/earthworm_svn/include -fPIC -DUSE__THREAD -I/usr/lib64/libffi-3.0.5/include -I/path/anaconda2/include/python2.7 -c c/_cffi_backend.c -o build/temp.linux-x86_64-2.7/c/_cffi_backend.o
In file included from /path/anaconda2/include/python2.7/Python.h:58,
from c/_cffi_backend.c:2:
/path/include/python2.7/pyport.h:886:2: error: #error "LONG_BIT definition appears wrong for platform (bad gcc/glibc config?)." error: command '/usr/bin/gcc' failed with exit status 1
Command "/root/.local/share/letsencrypt/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-I0WJ85/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-A5bxqp-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cffi" failed with error code 1 in /tmp/pip-build-I0WJ85/cffi
Does anyone know what the problem might be and how to go about fixing it?
Thank you,
Shawn
