Certbot resolves wrong IP
My domain is: spinsjoy-lp.com
I ran this command: certbot certonly --nginx -d spinsjoy-lp.com,www.spinsjoy-lp.com --dry-run
http-01 challenge for spinsjoy-lp.com
http-01 challenge for www.spinsjoy-lp.com
Failed authorization procedure. www.spinsjoy-lp.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.spinsjoy-lp.com/.well-known/acme-challenge/u7dYFihzZSgjFF7wXF7xcIVdUSrsN3LEaNkG4AEg9Fo [107.154.249.223]: "<html style="height:100%"><META NAME="ROBOTS" CONTENT="NOINDEX, NOFOLLOW"><meta name="format-detection" content="telephone", spinsjoy-lp.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://spinsjoy-lp.com/.well-known/acme-challenge/IcPvV5auOXjjU2tYgEHf3qCpLRDzI6BPGyVJvgV-efM [107.154.212.223]: "<html style="height:100%"><META NAME="ROBOTS" CONTENT="NOINDEX, NOFOLLOW"><meta name="format-detection" content="telephone"
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): Debian Buster
My hosting provider, if applicable, is: GCP
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
Very strange because I found here that some of people had that issue already. For example here
But it all seems goes to one point. Wrong DNS entry. Which in my case isn't the problem, my DNS is showing correct IP's
dig +short A spinsjoy-lp.com @pdns05.domaincontrol.com. ; dig +short A spinsjoy-lp.com @pdns06.domaincontrol.com.
107.154.212.223
107.154.248.223
107.154.212.223
107.154.248.223
I don't know how he get that 107.154.249.223 which is the issue here. From link above from other thread there is information that it uses our DNS from server where we run that command. But it seems that's not true.
Hi @eset
that's your DNS configuration, see your check, created yesterday - https://check-your-website.server-daten.de/?q=spinsjoy-lp.com
Host Type IP-Address is auth. ∑ Queries ∑ Timeout
spinsjoy-lp.com A 107.154.212.223 London/England/United Kingdom (GB) - Incapsula Inc Hostname: 107.154.212.223.ip.incapdns.net yes 1 0
A 107.154.248.223 London/England/United Kingdom (GB) - Incapsula Inc Hostname: 107.154.248.223.ip.incapdns.net yes 1 0
AAAA
That's the ip of your error message:
Looks like you have a wrong ip address defined.
The www subdomain is a CNAME for qcxnnga.x.incapdns.net.
Yes, but that's the same ip 107.154.248.223.
Nope, it resolves to 107.154.249.223:
Although the apex domain resolves to the correct 107.154.212.223 IP address and also returns HTML in stead of the token, so the DNS issue isn't the only issue here. It's probably also a nginx configuration issue.
Ah, the check is one day old, didn't rechecked the domain.
Check what DNS gives you
And I paste it here
107.154.212.223
107.154.248.223
107.154.212.223
107.154.248.223
So we stick to those IP addresses because they are valid
107.154.212.223
107.154.248.223
The issue here is 107.154.249.223 which isn't the valid one. The third octet makes difference here 249 instead of 248 and that's the issue.
Rechecked your domain:
AAAA yes
www.spinsjoy-lp.com CNAME qcxnnga.x.incapdns.net yes 1 0
That's your current configuration.
But checking
http://spinsjoy-lp.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
there is a http status 200, not the expected http status 404 - Not Found.
Looks like your application doesn't handle files correct.
What says
nginx -T
Sorry I don't understand what my nginx has to do with it. Osiris has a good point that cname resolves somehow to wrong IP which certbot have my in the error output. 107.154.249.223 != 107.154.248.223
regarging your URL status to that address.. ehm you said there is 200 instead of 404? Strange.. is obvious 404
<html>
<head><script src="/f-nowne-Macbeth-a-Daggersonry-selfe-to-the-labou" async></script><title>404 Not Found</title></head>
<body>
<center><h1>404 Not Found</h1></center>
<hr><center>nginx</center>
<script async type="text/javascript" src="/_Incapsula_Resource?SWJIYLWA=719d34d31c8e3a6e6fffd425f7e032f3&ns=1&cb=82697774"></script>
</body>
</html>```
Looks like you don't know your own system.
Downloading
http://www.spinsjoy-lp.com/.well-known/acme-challenge/1234
there is something with an iframe and a JavaScript.
<html style="height:100%"><head><META NAME="ROBOTS" CONTENT="NOINDEX, NOFOLLOW">
<meta name="format-detection" content="telephone=no"><meta name="viewport" content="initial-scale=1.0"><meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
<script type="text/javascript" src="/_Incapsula_Resource?SWJIYLWA=719d34d31c8e3a6e6fffd425f7e032f3"></script></head>
<body style="margin:0px;height:100%">
<iframe id="main-iframe" src="/_Incapsula_Resource?CWUDNSAI=20&xinfo=13-283075958-0%20NNNN%20RT%281617091540176%200%29%20q%280%20-1%20-1%200%29%20r%280%20-1%29%20B10%2814%2c0%2c0%29%20U18&incident_id=730000360308573455-955972240243558669&edet=10&cinfo=0e0000008e27&rpinfo=0" frameborder=0 width="100%" height="100%" marginheight="0px" marginwidth="0px">Request unsuccessful. Incapsula incident ID: 730000360308573455-955972240243558669</iframe>
</body></html>
The browser executes the JavaScript and redirects to a 404 page.
Certbot shows you two errors: one for the www subdomain with an incorrect IP address but also an error for the apex domain with the correct IP address: so the CNAME is not the only issue here.
Also, what the @#+&@£& is this JavaScript file?
http://spinsjoy-lp.com/f-nowne-Macbeth-a-Daggersonry-selfe-to-the-labou
Is your server hacked or something?
It's behind CDN and it's not my system it's developer system I have in Nginx special location layer 7 routing to include .well-known
It's Imperva Bot Protection. Like I said it's not the issue here. I have a lot of sites behind that CDN and Certbot works. Like I said IP address is the issue here as this gives the wrong IP. I'm pretty sure it will work correctly if it will be fixed. And the rest of the configuration which you found that's part of CDN configuration and I have over 22 sites there and they work easily with certbot being behind the CDN provider. So no, my website isn't hacked, quite opposite , it's secured :slight_smile:
I'm 80 % certain it won't. We'll see :slight_smile:
Here is a prove that .well-known locationw works well
curl -Is  http://spinsjoy-lp.com/.well-known/acme-challenge/dupa.html
HTTP/1.1 200 OK
Server: nginx
Date: Tue, 30 Mar 2021 08:35:49 GMT
Content-Type: text/html
Content-Length: 5
Last-Modified: Tue, 29 Dec 2020 23:01:28 GMT
ETag: "5febb548-5"
Accept-Ranges: bytes
Set-Cookie: visid_incap_2420280=e3vg3ub+TFqbibx6nlcnE+XiYmAAAAAAQUIPAAAAAABrKgzbtdLx72rWj/vay0i6; expires=Tue, 29 Mar 2022 10:04:56 GMT; HttpOnly; path=/; Domain=.spinsjoy-lp.com
Set-Cookie: nlbi_2420280=PYRJflxvAjptyVifH+SF5QAAAADDvbN6SNY+cbhRlvseV+mU; path=/; Domain=.spinsjoy-lp.com
Set-Cookie: incap_ses_447_2420280=W/4pESbJCS2HAPGKfBA0BuXiYmAAAAAAY7t5PE7ptA3FUJ+DjNhunw==; path=/; Domain=.spinsjoy-lp.com
Set-Cookie: ___utmvmLEuXokwZ=kdfLDQGNuTD; path=/; Max-Age=900
Set-Cookie: ___utmvaLEuXokwZ=PCNvXXj; path=/; Max-Age=900
Set-Cookie: ___utmvbLEuXokwZ=WZv
    XHGORalz: rtX; path=/; Max-Age=900
X-CDN: Imperva
X-Iinfo: 5-64758536-64758537 NNNY CT(0 -1 0) RT(1617093349088 0) q(0 0 0 -1) r(0 0) U6
It fails because of the DNS and yeah one of them should work and second not but I never face output when only one check worked. Each time if it comes to CDN if there are multiple IP address if one of them fails , second also gaves error. And the nginx config is automated using ansible so there is no way that configuration difference much. What difference is the server_name output. Thats all.
I see, so the CDN decides it returns an error even if it could have succeded. That would be the 20 % margin I build into my prediction :grin:
does certbot servers have a IP addresses which I can whitelist? I Believe it's because Captcha on CDN
Certbot is one of many ACME clients which can be used to get certificates from any CA using the ACME protocol. So there are no "certbot servers". You probably mean the Let's Encrypt validation servers and for that the answer is: no. Please see the following FAQ question:
Yeah I found that the issue is not with nginx but with CDN. We received extra security layer and that cut off Lets Encrypt Validation Servers :confused:
