Certbot renewal fails for unknow reason
Detail below:
certbot --renew is failing to renew, and this has worked in the past. We know we must be missing something, but can't see it.
cloud.waltoninstitute.ie
certbot renew
We have been using a configuration file
[renewalparams]
account = XXXXXXXXXXXXXXXX
authenticator = standalone
http01_port = 8888
If we start up a mini webserver on port 8888 we can hit it from outside.
There is a Haproxy on the external IP, with tcptump we have verified that port 8888 is accessible from outside and can see the requests coming in as far as certbot by running tcpdump on the same host as certbot is running.
Here is the message from the logfile.
Domain: YYYY.YYYY.YYYY
Type: connection
Detail: During secondary validation: XX.XX.XX.XX: Fetching http://YYYY.YYYY.YYYY/.well-known/acme-challenge/_VIb587g1Og3Ch9kgx0K_mevt62ys4wgZj1_RVcqIGc: Error getting validation data
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you're using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
2026-10-15 12:58:05,569:DEBUG:certbot.error_handler:Encountered exception:
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 91, in handle_authorizations
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 180, in _poll_authorizations
2026-10-15 12:58:05,569:DEBUG:certbot.error_handler:Calling registered functions
2026-10-15 12:58:05,570:INFO:certbot.auth_handler:Cleaning up challenges
2026-10-15 12:58:05,570:DEBUG:certbot.plugins.standalone:Stopping server at :::8888...
2026-10-15 12:58:05,632:WARNING:certbot.renewal:Attempting to renew cert (YYYY.YYYY.YYYY) from /etc/letsencrypt/renewal/YYYY.YYYY.YYYY.ie.conf produced an unexpected error: Some challenges have failed.. Skipping.
2026-10-15 12:58:05,635:DEBUG:certbot.renewal:Traceback was:
File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 462, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1208, in renew_cert
renewed_lineage = _get_and_save_cert(le_client, config, lineage=lineage)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 116, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 320, in renew_cert
new_cert, new_chain, new_key, _ = le_client.obtain_certificate(domains, new_key)
File "/usr/lib/python3/dist-packages/certbot/client.py", line 348, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 396, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
apache2
ubuntu 20.04
NA
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NO
http-01 needs to use port 80, this might mean that your haproxy instance runs on port 80 and forwards to port 8888, however you should test your setup by connecting to the external IP address on port 80.
So the requests from the outside are on port 80, but if something is forwarding them to that host on port 8888 then sure that should work. How many incoming requests do you see? Since there should be at least 5.
You can run certbot with --debug-challenges to keep the standalone server running, and try from many external locations to confirm connectivity. A failure "During secondary validation" usually means that it's a problem with connectivity from some parts of the Internet, even if there is connectivity from the "primary" validation location.
