NET::ERR_CERT_DATE_INVALID
Subject: democracystraightup.org
Issuer: R3
Expires on: Sep 25, 2022
Current date: Nov 7, 2022
My domain is: https://democracystraightup.org/
I ran this command: entrypoint: "/bin/sh -c 'while :; do certbot --force-renew; sleep 12h; done'"
It produced this output: Certbot doesn't know how to automatically configure the web server on this system. However, it can still get a certificate for you. Please run "certbot certonly" to do so. You'll need to manually configure your web server to use the resulting certificate.
The operating system my web server runs on is (include version): ubuntu 14
My hosting provider, if applicable, is: aws
/var/log/letsencrypt/letsencrypt.log
output:
022-11-07 16:30:45,466:DEBUG:certbot._internal.main:certbot version: 1.28.0
2022-11-07 16:30:45,467:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/local/bin/certbot
2022-11-07 16:30:45,467:DEBUG:certbot._internal.main:Arguments:
2022-11-07 16:30:45,467:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#n>
2022-11-07 16:30:45,500:DEBUG:certbot._internal.log:Root logging level set at 30
2022-11-07 16:30:45,506:DEBUG:certbot._internal.display.obj:Notifying user: Processing /etc/letsencrypt/renewal/democracystraightup>
2022-11-07 16:30:45,532:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default>
2022-11-07 16:30:45,570:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-09-25 19:14:>
2022-11-07 16:30:45,570:INFO:certbot._internal.renewal:Certificate is due for renewal, auto-renewing...
2022-11-07 16:30:45,570:INFO:certbot._internal.renewal:Non-interactive renewal: random delay of 25.579089865156615 seconds
curl -Ii https://acme-v02.api.letsencrypt.org/directory
HTTP/2 200
server: nginx
date: Mon, 07 Nov 2022 16:35:17 GMT
content-type: application/json
content-length: 659
cache-control: public, max-age=0, no-cache
replay-nonce: A5FEgymGAbJG0KdOh7r7Goyh-aV0Ak0osM8uAN-eXOmhwKg
x-frame-options: DENY
strict-transport-security: max-age=604800
