Certbot renew, passenger and nginx
Certbot tries to restart nginx whenever I ask it to renew certificates. I think it tries to treat it like it would treat nginx installed with apt-get, and it fails.
Passenger installs nginx into different directory (/opt/nginx/sbin/nginx), so I think this may be the problem.
This is how error looks like:
$ sudo certbot renew --dry-run #  --post-hook "/etc/init.d/nginx restart"
Processing /etc/letsencrypt/renewal/myapplication
.com.conf
http-01 challenge for myapplication
.com
http-01 challenge for www.myapplication
.com
nginx: [error] invalid PID number "" in "/run/nginx.pid"
Encountered exception during recovery:
  File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 75, in handle_authorizations
    resp = self._solve_challenges(aauthzrs)
  File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 126, in _solve_challenges
    resp = self.auth.perform(all_achalls)
  File "/usr/lib/python3/dist-packages/certbot_nginx/configurator.py", line 1048, in perform
    self.restart()
  File "/usr/lib/python3/dist-packages/certbot_nginx/configurator.py", line 858, in restart
    nginx_restart(self.conf('ctl'), self.nginx_conf)
  File "/usr/lib/python3/dist-packages/certbot_nginx/configurator.py", line 1118, in nginx_restart
    "nginx restart failed:\n%s\n%s" % (out.read(), err.read()))
certbot.errors.MisconfigurationError: nginx restart failed:
b''
b''
  File "/usr/lib/python3/dist-packages/certbot/error_handler.py", line 108, in _call_registered
    self.funcs[-1]()
  File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 310, in _cleanup_challenges
    self.auth.cleanup(achalls)
  File "/usr/lib/python3/dist-packages/certbot_nginx/configurator.py", line 1067, in cleanup
    self.restart()
b''
b''
Attempting to renew cert (myapplication
.com) from /etc/letsencrypt/renewal/myapplication
.com.conf produced an unexpected error: nginx restart failed:
b''
b''. Skipping.
  /etc/letsencrypt/live/myapplication
.com/fullchain.pem (failure)
**          (The test certificates below have not been saved.)
**          (The test certificates above have not been saved.)
Is there a workaround for that?
Do you happen to have two set of Nginx installed? (E.x. one from default yum or apt-get, another one from passdgnger?)
Thank you
I did. Actually, I had three: one from passenger and two from apt packages (nginx and nginx-common).
However, I already removed them before asking this question.
Perhaps these options will help you:
  --nginx-server-root NGINX_SERVER_ROOT
                        Nginx server root directory. (default: /etc/nginx or
                        /usr/local/etc/nginx)
  --nginx-ctl NGINX_CTL
                        Path to the 'nginx' binary, used for 'configtest' and
                        retrieving nginx version number. (default: nginx)
