Certbot renew not showing on SSL checker
My domain is: phukettravelandtours.com
I ran this command: Renewed SSL with Certsage
It produced this output: Success!
Your certificate was installed into cPanel.
My hosting provider, if applicable, is: Namecheap
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):1.4.1
I renewed the SSL Cert 6 hours ago and it is still showing expiry in 6 days, not 3 months.
How long should it take for the renewed SSL to show?
Did you install your certificate after renewing it?
Also, be sure to get CertSage ACME client (version 2.0.0) - easy webpage interface, optimized for cPanel, no commands to type, root not required, fully-automated certificate renewals, which supports automatic certificate renewals.
OK, thanks griffin, will update to 2.0.0
I'm in the process of putting together an illustrated guide of how to properly configure your files and folders in cPanel for optimal CertSage usage. I'll be posting it in a section of CertSage ACME client (version 2.0.0) - easy webpage interface, optimized for cPanel, no commands to type, root not required, fully-automated certificate renewals in the next day or so.
