Certbot Renew failure
Please see contents of /etc/apache2/sites-enabled/000-default.conf below updated
<VirtualHost *:80>
        # specifies what hostname must appear in the request's Host: header to
        #ServerName www.example.com
        DocumentRoot /var/www/html
        # error, crit, alert, emerg.
        # modules, e.g.
        #LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =unificontroller.rockfieldit.com
</VirtualHost>
I do not think you are using a backtick (`) character and the formatting is still a problem. But, we see enough to identify a problem.
A test request to unificontroller.rockfieldit.com should redirect to HTTPS based upon your Apache config. But, it does not. In fact, as I noted earlier, it looks like your management program for your unifi controller is connected to port 80 and not your apache server.
Example
curl -I unificontroller.rockfieldit.com
HTTP/1.1 302
Transfer-Encoding: chunked
Date: Tue, 25 Oct 2022 13:32:37 GMT
In above we see:
  • a 302 redirect but your apache config would do a 301
  • The Location: is not for HTTPS url
  • No "Server: Apache" header which I would expect from your basic apache config
You need to review your unifi settings to ensure port 80 (http) requests get to Apache. You may need to ask on a unifi forum about this.
Hi MikeMcQ
Thanks for your post above. I have ran a "curl -I unificontroller.rockfieldit.com and I noticed that output is different compared to your output earlier.
Date: Tue, 15 Nov 2022 14:33:46 GMT
Server: Apache/2.4.41 (Ubuntu)
You have to run that from outside your network.
From the Internet, we see:
curl -Ii unificontroller.rockfieldit.com
HTTP/1.1 302
Date: Tue, 15 Nov 2022 15:06:38 GMT
