Certbot renew fails
apparently it was .,.. now fixed
*:80 is a NameVirtualHost
default server kasdivi.com (/usr/local/etc/apache24/extra/httpd-vhosts.conf:1)
port 80 namevhost kasdivi.com (/usr/local/etc/apache24/extra/httpd-vhosts.conf:1)
alias www.kasdivi.com
port 80 namevhost wandjbrewers.com (/usr/local/etc/apache24/extra/httpd-vhosts.conf:28)
alias www.wandjbrewers.com
port 80 namevhost theoceanwindow.com (/usr/local/etc/apache24/extra/httpd-vhosts.conf:51)
alias www.theoceanwindow.com
*:443 is a NameVirtualHost
default server wandjbrewers.com (/usr/local/etc/apache24/extra/httpd-vhosts.conf:74)
port 443 namevhost wandjbrewers.com (/usr/local/etc/apache24/extra/httpd-vhosts.conf:74)
alias wandjbrewers.com
port 443 namevhost theoceanwindow.com (/usr/local/etc/apache24/extra/httpd-vhosts.conf:98)
port 443 namevhost kasdivi.com (/usr/local/etc/apache24/extra/httpd-vhosts.conf:120)
I corrected httpd.conf. ran your big line again and got
**Saving debug log to /var/log/letsencrypt/letsencrypt.log
http-01 challenge for theoceanwindow.com
http-01 challenge for www.theoceanwindow.com
Using the webroot path /usr/local/www/wandjbrewers.com for all unmatched domains.
Running deploy-hook command: sudo /usr/local/sbin/apachectl graceful
Output from deploy-hook command sudo:
Performing sanity check on apache24 configuration:
Performing a graceful restart
Error output from deploy-hook command sudo:
Syntax OK
    /usr/local/etc/letsencrypt/live/kasdivi.com/fullchain.pem
    /usr/local/etc/letsencrypt/live/kasdivi.com/privkey.pem
    Your cert will expire on 2021-01-23. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    "certbot renew"
    Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
    Donating to EFF: **
which I assume mean you nailed it.!
:partying_face:
Now, once more with feeling for confidence:
sudo certbot renew --dry-run
all together now!!
Processing /usr/local/etc/letsencrypt/renewal/kasdivi.com.conf
http-01 challenge for wandjbrewers.com
http-01 challenge for www.wandjbrewers.com
http-01 challenge for kasdivi.com
http-01 challenge for www.kasdivi.com
Dry run: skipping deploy hook command: sudo /usr/local/sbin/apachectl graceful
new certificate deployed without reload, fullchain is
/usr/local/etc/letsencrypt/live/kasdivi.com/fullchain.pem (success)
** (The test certificates above have not been saved.)strong text
That's what we like to see! :grin:
Now about that mixed content for https://theoceanwindow.com...
Check https://theoceanwindow.com with the following tool and change the http's to https's:
all fixed I had been unaware. now aware\
Mixed content is any reference in your https webpage that is served over http, but should be served over https. This is why https://theoceanwindow.com shows no padlock next to the address.
You also need 301 redirects for all three sites from http to https.
