My domains are: coda-usa.com, www.coda-usa.com, cfs.coda-usa.com
I ran this command: certbot renew --dry-run
Processing /etc/letsencrypt/renewal/cfs.coda-usa.com.conf
Simulating renewal of an existing certificate for cfs.coda-usa.com
Processing /etc/letsencrypt/renewal/coda-usa.com.conf
Simulating renewal of an existing certificate for coda-usa.com and www.coda-usa.com
Domain: coda-usa.com
Detail: 3.239.174.56: Invalid response from https://www.coda-usa.com: "<!DOCTYPE html>\n<html lang=\"en-US\">\n<head>\n <meta charset=\"utf-8\">\n <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n"
Failed to renew certificate coda-usa.com with error: Some challenges have failed.
The following simulated renewals succeeded:
/etc/letsencrypt/live/cfs.coda-usa.com/fullchain.pem (success)
The following simulated renewals failed:
/etc/letsencrypt/live/coda-usa.com/fullchain.pem (failure)
My web server is (include version): nginx version: nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 22.04.4 LTS
My hosting provider, if applicable, is: Amazon US-EAST
or certbot-auto --version
if you're using Certbot): certbot 1.21.0
CURL test: cfs.coda-usa.com
# curl -I https://cfs.coda-usa.com/.well-known/acme-challenge/Challenge-Test-123 HTTP/1.1 200 OK Server: nginx/1.18.0 (Ubuntu) Date: Thu, 25 Jul 2024 14:09:04 GMT Content-Type: text/html Content-Length: 445 Last-Modified: Wed, 17 Jul 2024 19:24:43 GMT Connection: keep-alive ETag: "66981a7b-1bd" Content-Security-Policy: font-src 'self' https://use.typekit.net/af/ https://use.typekit.net/xcy8qgg.css/; frame-ancestors 'self'; frame-src 'self'; style-src 'self' 'unsafe-inline' https://use.typekit.net/xcy8qgg.css/; style-src-elem 'self' 'unsafe-inline' https://use.typekit.net/xcy8qgg.css/; Accept-Ranges: bytes
CURL test: www.coda-usa.com
# curl -I https://www.coda-usa.com/.well-known/acme-challenge/Challenge-Test-123 HTTP/1.1 404 Not Found Server: nginx/1.18.0 (Ubuntu) Date: Thu, 25 Jul 2024 14:10:44 GMT Content-Type: text/html; charset=utf-8 Connection: keep-alive Set-Cookie: CODASESSIDs=quac71f1h8ke5n1ugerjrqubfh; path=/; secure; HttpOnly; SameSite=Lax Expires: Thu, 19 Nov 1981 08:52:00 GMT Cache-Control: no-store, no-cache, must-revalidate Pragma: no-cache X-Powered-By: ProcessWire CMS
CURL test: coda-usa.com
# curl -I https://coda-usa.com/.well-known/acme-challenge/Challenge-Test-123 HTTP/2 301 date: Thu, 25 Jul 2024 14:15:58 GMT content-type: text/html content-length: 167 location: https://www.coda-usa.com cache-control: max-age=3600 expires: Thu, 25 Jul 2024 15:15:58 GMT report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=M6duV6Z0XxPFr8OVS41eSBa00moYIcdklYvB6avr42jureY07PlxmhJhi%2F%2F%2Bc0poAcfTuxCm6Fw1Ir%2BHzhH9Vw9hmGd51wbZs3lhgpVRh2ycGStnjEeS45lAl3DnxC0%3D"}],"group":"cf-nel","max_age":604800} nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800} server: cloudflare cf-ray: 8a8cc3dd29fa9c1f-IAD
I'm not sure what else to check now. Any assistance would be greatly appreciated.
