Certbot renew don't work
Hello, I have a server that is now more than a year old, the certificate was automatically renewed without any problem even if I remember that it bothered me at first. The certificate was not renewed, I did everything, but I can't do it. NEED HELP PLEASE
My domain is: apisnix-crm.com
certbot renew
Processing /etc/letsencrypt/renewal/apisnix-crm.com.conf
http-01 challenge for apisnix-crm.com
Using the webroot path /srv/www/htdocs for all unmatched domains.
Challenge failed for domain apisnix-crm.com
Attempting to renew cert (apisnix-crm.com) from /etc/letsencrypt/renewal/apisnix-crm.com.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/apisnix-crm.com/fullchain.pem (failure)
    Domain: apisnix-crm.com
    Type: connection
    Detail: 151.236.39.57: Fetching
    https://151.236.39.57/.well-known/acme-challenge/B0-WxwFEl3IALuLQXm5swnCmStvHrZWl1mPZwq0AfyM:
    Invalid host in redirect target "151.236.39.57". Only domain names
    are supported, not IP addresses
My web server is (include version): vicidial (opensuse 15.2)
My certbot version is: 1.4.0
I try:
certbot renew
Certbot certonly --webroot
certbot renew --force-renewal --cert-name apisnix-crm.com --dry-run
certbot renew -a webroot -w /var/www/html --dry-run
certbot -d apisnix-crm.com --force-renewal
certbot renew --preferred-challenges -d
certbot run -a webroot -i apache -w /srv/www/htdocs -d apisnix-crm.com --debug-challenges
certbot certonly --cert-name apisnix-crm.com
certbot rollback
certbot renew --break-my-certs
certbot renew --quiet
Thank you in advance
Hello @Franck98, welcome to the Let's Encrypt community. :slightly_smiling_face:
Checkout Let's Debug
apisnix-crm.com has an A (IPv4) record (151.236.39.57) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Get "https://151.236.39.57/.well-known/acme-challenge/letsdebug-test": No AAAA or A records were found for 151.236.39.57
Best Practice - Keep Port 80 Open
Also previously you have gotten certificates https://crt.sh/?q=apisnix-crm.com
Also this error:
151.236.39.57: Fetching https://151.236.39.57/.well-known/acme-challenge/otnZFysQnuHxDV6Pyp3KJHXkzD5FTHlBKPCwda_mZZU: Invalid host in redirect target "151.236.39.57". Only domain names are supported, not IP addresses
Your server redirected the original HTTP challenge request to an IP address. This is not allowed. See here about redirects:
As Let’s Encrypt offers Domain Validation (DV) certificates; IP Addresses are not a Domain.
Hello and thank you for your very quick answers, excuse the language, I'm French speaking.
I have opened port 80 but anyway, I disable firewalld before renewing (advice from another technician last year)
I have read the articles and links you sent me and I am starting to see the problem but what should I do concretely please ?
Please do NOT use this option if you don't understand what it actually does. It does NOT magically renew your certificate if there is a validation problem. Using this option carelessly potentially adds unnecessary strain/load on the Let's Encrypt infrastructure and can lead you running into rate limits, denying you any further certificate for a certain amount of time.
Your webserver should not redirect to the IP address of your site. Why would it do that in the first place?
okay boss, I won't do it again
I just checked and honestly, I don't know but in July, I did a lot of manipulations on the server (there were some issues). I send you the results of the virtual hosts ecause I think there is a problem there
apachectl -t -D DUMP_VHOSTS
which: no w3m in (/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin)
which: no lynx in (/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin)
AH00558: httpd-prefork: Could not reliably determine the server's fully qualified domain name, using 151.236.39.57. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443                  apisnix-crm.com (/etc/apache2/vhosts.d/1111-default-ssl.conf:1)
*:80                   vicibox.company.com (/etc/apache2/vhosts.d/1111-default.conf:1)
*:446                  dynportalcompany.com (/etc/apache2/vhosts.d/dynportal-ssl.conf:1)
*:81                   dynportal.company.com (/etc/apache2/vhosts.d/dynportal.conf:1)
 nano /etc/apache2/vhosts.d/1111-default-ssl.conf
  GNU nano 4.9.2                                                            /etc/apache2/vhosts.d/1111-default-ssl.conf
<VirtualHost _default_:443>
        ServerAdmin admin@apisnix-crm.com
        ServerName apisnix-crm.com
        #ServerAlias
        DocumentRoot /srv/www/htdocs
        ErrorLog /var/log/apache2/error_log
        #CustomLog /var/log/apache2/access_log combined
        CustomLog /dev/null combined
        HostnameLookups Off
        UseCanonicalName Off
        ServerSignature Off
        TraceEnable Off
        Include /etc/apache2/conf.d/*.conf
        DirectoryIndex index.html index.php index.htm
        SSLEngine on
        SSLCertificateFile /etc/certbot/live/apisnix-crm.com/cert.pem
        SSLCACertificateFile /etc/certbot/live/apisnix-crm.com/fullchain.pem
        SSLCertificateKeyFile /etc/certbot/live/apisnix-crm.com/privkey.pem
        <FilesMatch "\.(cgi|shtml|phtml|php)$">
                SSLOptions +StdEnvVars
        </FilesMatch>
        BrowserMatch "MSIE [2-5]" nokeepalive ssl-unclean-shutdown downgrade-1.0 force-response-1.0
        <Files ~ "^\.ht">
                Require all denied
        </Files>
        <Files ~ "opcache.php">
                Require ip 10.0.0.0/8 192.168.0.0/16 172.16.0.0/12 127.0.0.1
        </Files>
        <Directory "/srv/www/htdocs">
nano /etc/apache2/vhosts.d/1111-default.conf
  GNU nano 4.9.2                                                              /etc/apache2/vhosts.d/1111-default.conf
<VirtualHost _default_:80>
        ServerAdmin admin@company.com
        ServerName vicibox.company.com
        #ServerAlias
        Redirect permanent / https://151.236.39.57/
        HostnameLookups Off
        ServerSignature Off
        TraceEnable Off
        <Files ~ "^\.ht">
                Require all denied
        </Files>
        </Files>
                AllowOverride None
                Require all granted
        </Directory>
        ### Uncomment this if you want PCI-DSS WebScan results to pass, but it'll likely mess up scripting in vicidial
        #<IfModule mod_headers.c>
        #       Header always set X-Frame-Options: DENY
        #       Header always set X-XSS-Protection "1; mode=block"
        #       Header always set X-Content-Type-Options: nosniff
        #       Header always set Content-Security-Policy "script-src 'self'; object-src 'self'"
        #       Header always set Strict-Transport-Security "max-age=63072000; includeSubdomains;"
        #</IfModule>
        ### To force everything to SSL uncomment the following
        #RewriteEngine On
        #RewriteCond %{HTTPS} off
        #RewriteRule (.*) https://%{SERVER_NAME}/$1 [R,L]
/etc/apache2/vhosts.d/1111-default.conf is the configuration file for an entirely different hostname, not for apisnix-crm.com. Where did the HTTP (port 80) virtualhost for apisnix-crm.com go?
I don't know what to tell you, I can only tell you that the present name is the system default name and not the name of a third party
If you want a certificate for the hostname apisnix-crm.com, your Apache needs to be configured for that hostname with a HTTP (port 80) virtualhost, which currently is not the case.
Should I copy the contents of 1111-default-ssl.conf to 1111-default.conf or just change the servername?
I will try both but I would like to know if it can work or if apache doesn't have a command to do it in its system?
I can't advise you on how you need to configure your Apache. This is not the correct Community for that. And also I have absolutely no idea what kind of directives certain sites of your system need.
In any case I would not advise to just change the servername. That would disable the virtualhost for the original hostname if you'd do that, which I would not recommend. Copying contents of "random" configuration files is also not something I would advise. If I were you, I would write a new configuration file entirely. If you have a working HTTPS (port 443) virtualhost, the HTTP port 80 virtualhost doesn't need to be complex. In fact, it could exist purely of a HTTP to HTTPS redirect.
Thanks a lot for your help,
you just had to fill in the ServerName in httpd.conf
The ServerName track was the right one, I used this site
How does that "bypass" the redirection to an IP address problem?:
Furthermore, there is only one vhost that covers port 80.
And it has the same document root as the one in question.
So, "that" wasn't part of the problem.
Is it fixed now?
Let's Debug https://letsdebug.net/ Test result for apisnix-crm.com using http-01 is still failing.
New certificates have been issued also https://crt.sh/?q=apisnix-crm.com
Ghe, entirely missed that redirect, I only saw the commented out RewriteEngine redirect :roll_eyes:
Although SSL Server Test: apisnix-crm.com (Powered by Qualys SSL Labs) is passing. :thinking:
sorry, I was correcting and adjusting the phone
yes it works
