Certbot not using port
My domain is: portc.3bbddns.com
I ran this command: sudo certbot certonly --manual --http-01-port 47810
It produced this output: Domain: portc.3bbddns.com
Type: connection
Detail: 110.164.204.27: Fetching http://portc.3bbddns.com/.well-known/acme-challenge/V2CabgUSz1B1wdSolYbLBtuB6QwPEW6KNsQumXYB0kc: Timeout during connect (likely firewall problem)
My web server is (include version): nginx 1.18.0
The operating system my web server runs on is (include version): ubuntu 22.04 lts
My hosting provider, if applicable, is: non
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21.0
usually how i would access the server is portc.3bbddns.com:47810 and http://portc.3bbddns.com:47810/.well-known/acme-challenge/V2CabgUSz1B1wdSolYbLBtuB6QwPEW6KNsQumXYB0kc show the token fine, im guessing cerbot didnt use portc.3bbddns.com:47810 and use portc.3bbddns.com instead
The HTTP-01 challenge can only be done on port 80. Allowing clients to specify arbitrary ports would make the challenge less secure, and so it is not allowed by the ACME standard.
HTTP-01 challenge
--http-01-port option exists to be able to port-forward/reverse-proxy 80→<specified_port>
oh then how do i use TLS-ALPN-01 since my ddns is provided by my isp and gave me port 47810 to 47819 to work with and i cant change them, also it only redirect http request to my router so theres no option to add a dns record
Certbot does not have tls-alpn-01 capabilities, only http-01 and dns-01. There are other ACME clients which do have tls-alpn-01 support.
Note that tls-alpn-01 requires port 443 to be accessible.
Also note that the ACME client might influence the challenge used, but it's up to the ACME server to do the validation. Not Certbot or any other ACME client. ACME clients cannot influence the details of a challenge, such as the port used to connect to.
I guess that only happens on IPv4. Does your ISP support IPv6?
You may want to use the DNS-01 challenge method.
Can you use another ISP?
While this is going to be leaning off topic for deep discussion here, it is worth mentioning that Cloudflare now has Origin Rules that allow you to map to non-standard ports on your origin server. You can discuss this in the Cloudflare Community if you think it might be useful. DNS-01 challenges are reasonably straightforward on Cloudflare as well.
