Certbot not renewing, challenge fails with empty string
I have taken over a Digital Ocean server at work by an employee who is no longer here and some of our certificates are not renewing. I’m not really a ‘server guy’ so this is out of my comfort zone and I could use some pointers.
I know all of the certificates were being renewed in the past as I’d integrated several StatusCake tests with our team’s Discord server. I would see the upcoming expiration notice and then a successful renewal. This has stopped recently and two domains expired and I can’t renew them successfully. I’ll fill out the questions here and provide as much detail as I can.
I’m concerned that the challenges which fail are failing with an empty string. Several domains are showing this. I’ve provided the output below.
My domain is: www.keylogic.ca keylogic.ca
Attempting to renew cert (keylogic.ca) from /etc/letsencrypt/renewal/keylogic.ca.conf produced an unexpected error: Failed authorization procedure. www.keylogic.ca (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: The key authorization file from the server did not match this challenge “AP5zJP33NVm6GlP-RBXISaeZTys-9O4wOfHl1czGf9Q.E1QS09vT95l-xxWbiWnUP24ePZ9EgKsRo_YTObqj4eE” != “”, keylogic.ca (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: The key authorization file from the server did not match this challenge “YZ1-JXd4WOkaVCi9XIYIfpnzkZpPbIKVMOG86CLi6K8.E1QS09vT95l-xxWbiWnUP24ePZ9EgKsRo_YTObqj4eE” != “”. Skipping.
Domain: keylogic.ca
Detail: The key authorization file from the server did not match
this challenge
My web server is (include version): Apache 2.4.29
OS: Ubuntu 18.04.1 LTS (GNU/Linux 4.15.0-99-generic x86_64)
My hosting provider, if applicable, is: Amazon
Hi @patrickatkeylogic
your webserver configuration is buggy.
Checking
http://www.keylogic.ca/.well-known/acme-challenge/1234
there isn't an error / http status 404 Not Found, instead there is a http status 200 - and an empty result.
Why?
Fix that.
Thanks for the reply.
I think we should see the token when going to that URL? I’m betting one of the redirects is buggy (we redirect HTTP traffic to HTTPS). I also don’t see a .well-known directory anywhere in the web root so that might be another issue.
That's the expected result, yes, when certbot is being ran. The 1234 test file should result in a 404 file not found error though.
That's not a webserver. A valid answer could have been "Apache", "nginx", "openresty", "Varnish" among others.
Seems to be an issue in your openresty configuration.
Whoops, I’ll update the post. It’s Apache/2.4.29.
I’ll dig into the redirects. Thanks for the help.
I'm only seeing openresty and/or Varnish in the HTTP headers?
That actually might be the crux of the issue. The failing URLs are now pointing to a webflow site that a contractor built recently. I should have seen it earlier but it happened pretty recently.
Thanks again for the help.
