Okay, at least, when visiting https://bitwarden.niggipi.duckdns.org/
I now get a message that the Cert is invalid.
When running certbot again, I now get the following message:
nginx: [warn] "ssl_stapling" ignored, issuer certificate not found for certificate "/etc/ssl/certs/ssl-cert-snakeoil.pem"
Failed authorization procedure. bitwarden.niggipi.duckdns.org (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://niggipi.duckdns.org/.well-known/acme-challenge/iOTn7PnFvDQeSfZU7pHR2VZub0pxXnP6pVvsSIDHdSU: Connection refused
rg305
August 20, 2021, 10:23am
#22
The point of that was to get nginx
to stand up and walk (not run).
[at least it is no longer fallen and can't get up ]
We still need to fix it so it can run (properly).
To that end, you now need to reissue new cert(s).
But that was hampered by:
It's now time to deal with that problem.
Please show outputs of:
curl -4 ifconfig.co
curl -6 ifconfig.co
Since bitwarden.niggipi.duckdns.org seems to be reachable, I think the problem with niggipi.duckdns.org is, that nginx is not acting as a proxy for niggipi.duckdns.org but as a web server. The proxy for bitwarden.niggipi.duckdns.org seems to work fine. Does this make sense?
rg305
August 20, 2021, 10:30am
#24
niggiover9000:
Maybe.
Please also show the file:
[to better understand you]
listen 80;
server_name bitwarden.niggipi.duckdns.org;
# SSL configuration
listen 443 ssl default_server;
listen [::]:443;
# Certs
ssl_certificate /etc/ssl/certs/ssl-cert-snakeoil.pem; # only temporary
ssl_certificate_key /etc/ssl/private/ssl-cert-snakeoil.key; # only temporary
# Improve HTTPS performance with session resumption
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 5m;
# Enable server-side protection against BEAST attacks
ssl_prefer_server_ciphers on;
ssl_ciphers ECDH+AESGCM:ECDH+AES256:ECDH+AES128:DH+3DES:!ADH:!AECDH:!MD5;
# Disable SSLv3
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
# Diffie-Hellman parameter for DHE ciphersuites
ssl_dhparam /etc/ssl/certs/dhparam.pem;
# Enable HSTS (https://developer.mozilla.org/en-US/docs/Security/HTTP_Strict_Transport_Security)
add_header Strict-Transport-Security "max-age=63072000; includeSubdomains";
# Enable OCSP stapling (http://blog.mozilla.org/security/2013/07/29/ocsp-stapling-in-firefox)
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.8.8 8.8.4.4 valid=300s;
resolver_timeout 5s;
proxy_pass http://192.168.0.254:7000;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
# proxy_set_header Connection $connection_upgrade;
rg305
August 20, 2021, 10:34am
#26
OK so I see what you mean.
Is there supposed to be a proxy line within the other ssl enabled file?
We still have a port 80 problem to deal with.
Please show the outputs of:
netstat -pant | grep -Ei 'nginx|80|443'
and
grep -Ri listen /etc/nginx
And there us also an IPv4/IPv6 listening problem:
Addresses: 2a02:8071:2b4:a700:453a:29e2:7f2b:60d4
82.165.242.73
But the server is not listening to both:
It is missing a line:
listen [::]:80;
returns:
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 16513/nginx: master
tcp 0 0 0.0.0.0:8000 0.0.0.0:* LISTEN 2016/docker-proxy
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 16513/nginx: master
tcp 0 0 192.168.0.254:47314 165.254.191.194:443 VERBUNDEN 725/vncserver-x11-c
tcp6 0 0 :::443 :::* LISTEN 16513/nginx: master
tcp6 0 0 :::8000 :::* LISTEN 2027/docker-proxy
returns:
/etc/nginx/sites-available/default: listen 80 default_server;
/etc/nginx/sites-available/default: listen [::]:80 default_server;
/etc/nginx/sites-available/default: # listen 443 ssl default_server;
/etc/nginx/sites-available/default: # listen [::]:443 ssl default_server;
/etc/nginx/sites-available/default:# listen 80;
/etc/nginx/sites-available/default:# listen [::]:80;
/etc/nginx/sites-available/files.niggipi.duckdns.org: listen [::]:80;
/etc/nginx/sites-available/files.niggipi.duckdns.org: listen 80;
/etc/nginx/sites-available/files.niggipi.duckdns.org: listen 443 ssl http2;
/etc/nginx/sites-available/files.niggipi.duckdns.org: listen [::]:443 ssl http2;
/etc/nginx/sites-available/bitwarden.niggipi.duckdns.org.conf: listen 80;
/etc/nginx/sites-available/bitwarden.niggipi.duckdns.org.conf: listen 443 ssl default_server;
/etc/nginx/sites-available/bitwarden.niggipi.duckdns.org.conf: listen [::]:443;
/etc/nginx/sites-available/deck.niggipi.duckdns.org: listen [::]:80;
/etc/nginx/sites-available/deck.niggipi.duckdns.org: listen 80;
/etc/nginx/sites-available/deck.niggipi.duckdns.org: listen 443 ssl http2;
/etc/nginx/sites-available/deck.niggipi.duckdns.org: listen [::]:443 ssl http2;
/etc/nginx/sites-available/mail.niggipi.duckdns.org: listen [::]:80;
/etc/nginx/sites-available/mail.niggipi.duckdns.org: listen 80;
/etc/nginx/sites-available/mail.niggipi.duckdns.org: listen 443 ssl http2;
/etc/nginx/sites-available/mail.niggipi.duckdns.org: listen [::]:443 ssl http2;
/etc/nginx/sites-available/cospend.niggipi.duckdns.org: listen [::]:80;
/etc/nginx/sites-available/cospend.niggipi.duckdns.org: listen 80;
/etc/nginx/sites-available/cospend.niggipi.duckdns.org: listen 443 ssl http2;
/etc/nginx/sites-available/cospend.niggipi.duckdns.org: listen [::]:443 ssl http2;
/etc/nginx/sites-available/niggipi.duckdns.org:# listen 80;
/etc/nginx/sites-available/niggipi.duckdns.org:# listen [::]:80;
/etc/nginx/sites-available/niggipi.duckdns.org:# listen 443 ssl http2;
/etc/nginx/sites-available/niggipi.duckdns.org:# listen [::]:443 ssl http2;
/etc/nginx/sites-available/niggipi.duckdns.org: listen 443 ssl http2;
/etc/nginx/sites-available/niggipi.duckdns.org: listen [::]:443 ssl http2;
/etc/nginx/sites-enabled/bitwarden.niggipi.duckdns.org.conf: listen 80;
/etc/nginx/sites-enabled/bitwarden.niggipi.duckdns.org.conf: listen 443 ssl default_server;
/etc/nginx/sites-enabled/bitwarden.niggipi.duckdns.org.conf: listen [::]:443;
/etc/nginx/sites-enabled/niggipi.duckdns.org:# listen 80;
/etc/nginx/sites-enabled/niggipi.duckdns.org:# listen [::]:80;
/etc/nginx/sites-enabled/niggipi.duckdns.org:# listen 443 ssl http2;
/etc/nginx/sites-enabled/niggipi.duckdns.org:# listen [::]:443 ssl http2;
/etc/nginx/sites-enabled/niggipi.duckdns.org: listen 443 ssl http2;
/etc/nginx/sites-enabled/niggipi.duckdns.org: listen [::]:443 ssl http2;
/etc/nginx/nginx.conf:# listen localhost:110;
/etc/nginx/nginx.conf:# listen localhost:143;
rg305
August 20, 2021, 10:40am
#28
Reduced to /sites-enabled/
and NOT commented out and separated by file:
You can see that not all sites are being served on all ports and on both IPv4 & IPv6.
There are missing lines and vhost configs.
and other problems...
[one at a time]
rg305
August 20, 2021, 10:48am
#29
Both names resolve to both IPs:
82.165.242.73
82.165.242.73
So they should be served by both IPs.
They are for 443:
But not for 80.
And nothing seems to be served on 80 at all right now; I only get:
Is there a firewall or NAT device responsible to sending 82.165.242.73:80 to 192.168.0.254:80 ?
Yeah, forgot to mention: because my ISP does use DS-lite, I use an external server (82.165.242.73), which tunnels all the traffic over SSH to my home server. I just checked the server and it does indeed only show port 443 as open and port 80 as closed.
rg305
August 20, 2021, 10:52am
#31
This, you say on post #30 ?
I'm really trying to help you - with what is obviously nothing to do with certbot
nor LetsEncrypt
You have to help me help you or this is really not worth the trouble for me.
Yeah, didn't think this could be the problem, haven't touched the external server for like a year.
rg305
August 20, 2021, 10:55am
#33
You are going to need port 80 for HTTP authentication.
Which is what I suspect you were using to renew the certs.
We can check that with:
cat /etc/letsencrypt/renewal/*
rg305
August 20, 2021, 10:59am
#34
Do you want to continue?
Or are we done for today?
Oh my...
returns
Datei oder Verzeichnis nicht gefunden (File or folder not found)
Man, I have the feeling, this is getting too big for me. I don't want to waste your time any more
It think, I will gonna set everything up from scratch!
rg305
August 20, 2021, 11:04am
#36
Reread my first post.
And your reply to it.
You need to fix the port 80 problem first.
Or you must switch away from HTTP-01 and do DNS-01 authentication.
Good night and best of luck to you.
Cheers from Miami
#FreeCUBA
Thank you for your help! I will give a feedback when I found a solution for the port 80 problem!
Thank you so much!
The problem was a misconfigured crontab, that only established an ssh tunnel for port 443 only. Now it is working again.
If anyone should have the same problem in the future: here is the crontab, that I changed:
@reboot autossh -M 0 -f -o ConnectTimeout=10 -o ServerAliveInterval=60 -o ServerAliveCountMax=2 -p 39001 -N -R 443:localhost:443 root@82.165.242.73
@reboot autossh -M 0 -f -o ConnectTimeout=10 -o ServerAliveInterval=60 -o ServerAliveCountMax=2 -p 39001 -N -R 80:localhost:80 root@82.165.242.73
rg305
August 20, 2021, 4:32pm
#39
Thank you for the
I hope you are now able to get all new certs and as many as you need
Cheers from Miami
#FreeCUBA
system
closed
September 19, 2021, 4:33pm
#40
