Certbot --nginx fails for same configuration across sites
Dear community,
I’ve encountered issues with using certbot for a number of domains which share basically the same setup. It is a tad intricate, so some explanations first.
I have four domains:
a-a.org is the target domain, so to speak, as all other three redirect to the same subdirectory of it. a-a.org also has a subdomain x.a-a.org which redirects to the same subdirectory.
In nginx this looks like the following.
x.a-a.org (Subdomain)
	root /var/www/a-a.org/x;
	server_name x.a-a.org;
	    return 301 https://a-a.org/x$request_uri;
a-a.org (“Main” domain)
	root /var/www/a-a.org;
	server_name a-a.org www.a-a.org;
		try_files $uri $uri/ =404;
b-b.org, c-c.org, d.org (The three secondary domains):
server_name d.org www.d.org;
location = / {
    return 301 https://a-a.org/x;
server_name b-b.org www.b-b.org;
location = / {
When I run
certbot --nginx
I get the following results:
$ sudo certbot --nginx
1: d.org
2: www.d.org
3: a-a.org
4: x.a-a.org
5: www.a-a.org
6: b-b.org
7: www.b-b.org
9: c-c.org
10: www.c-c.org
requested (ref: /etc/letsencrypt/renewal/other-domain.conf)
It contains these names: d.org, x.a-a.org,
other-domain, a-a.org, www.d.org,
www.a-a.org
You requested these names for the new certificate: d.org,
www.d.org, a-a.org, x.a-a.org,
www.a-a.org, b-b.org, www.b-b.org,
other-domain, c-c.org,
www.c-c.org.
certificate?
(E)xpand/(C)ancel: E
http-01 challenge for d.org
http-01 challenge for www.d.org
http-01 challenge for a-a.org
http-01 challenge for x.a-a.org
http-01 challenge for www.a-a.org
http-01 challenge for b-b.org
http-01 challenge for www.b-b.org
tls-sni-01 challenge for other-domain
http-01 challenge for c-c.org
http-01 challenge for www.c-c.org
nginx: [warn] conflicting server name "x.a-a.org" on 0.0.0.0:80, ignored
   Domain: c-c.org
   Type:   unauthorized
   Detail: Invalid response from
   http://c-c.org/.well-known/acme-challenge/{key}:
   "<html>
   <head><title>404 Not Found</title></head>
   <body bgcolor="white">
   <center><h1>404 Not Found</h1></center>
   <hr><center>"
   Domain: www.c-c.org
   Type:   unauthorized
   http://www.c-c.org/.well-known/acme-challenge/{key}:
   "<html>
   <hr><center>"
   Domain: b-b.org
   Type:   unauthorized
   http://b-b.org/.well-known/acme-challenge/{key}:
   "<html>
   <hr><center>"
   Domain: www.b-b.org
   Type:   unauthorized
   http://www.b-b.org/.well-known/acme-challenge/{key}:
   "<html>
   <hr><center>"
So basically, b-b.org and c-c.org didn’t go through, while d.org worked fine despite having the same setup.
I’d be thankful for any pointer as to why this could possibly be the case.
All domains share the same IPv4 and IPv6 IPs…
Can you try comment off the location block?
Also, please fill in the form below:
should move to Help
Thank you
Thanks!
I’m providing the details for one of the domains that is failing, as it is failing attempting to install a cert only for that one. I’ve hit rate limits in the meantime, so will not be able to check solutions before next week/month I guess?
The nginx config you ask to be commented out would not be hit by the actual config of this domain, so I left it out here (but have tried it, it didn’t make any difference).
Can you try to create a file under your root for this domain?
(aka please try to create a file under /var/www/research-software.org/.well-known/acme-challenge/ and visit the link? )
and temporarily comment out the location block?
Then please visit the file you created under the directory to test
Thank you
Hi @sdruskat,
As @stevenzhu said, you should do this
And you should only continue when you can reach that file from internet, also, before you get crazy, Let's Encrypt prefers IPv6 over IPv4 and as you are advertising an AAAA record for your domains, Let's encrypt will try to validate them using the IPv6 connection but your server is not configured in the same way for IPv6 as it is for IPv4.
Using IPv4:
$ curl -I4kL http://wissenschaftliche-software.org/
Server: nginx/1.10.3 (Ubuntu)
Date: Thu, 22 Feb 2018 17:25:56 GMT
Content-Type: text/html
Content-Length: 194
Date: Thu, 22 Feb 2018 17:25:57 GMT
Content-Length: 194
HTTP/1.1 200 OK
Content-Length: 18006
Last-Modified: Sun, 18 Feb 2018 22:25:30 GMT
ETag: "5a89fd5a-4656"
Accept-Ranges: bytes
Using IPv6:
$ curl -I6kL http://wissenschaftliche-software.org/
HTTP/1.1 404 Not Found
Date: Thu, 22 Feb 2018 17:26:03 GMT
Content-Length: 178
So you should configure your server properly to answer IPv6 requests the same way as for IPv4 or remove the AAAA records for your domains.
Good luck,
sahsanu
Thanks both, will try as you advised before getting back :).
The file is reachable at Research Software Engineers | Research Software Engineers International (0b touch-created).
@sdruskat, please, put some text in that file, just "This is a test" so we know we are reaching the right file.
@sahsanu It's now Research Software Engineers | Research Software Engineers International and should read "certbot test"... Thanks!
Ok, now, with research-software.org is working fine using IPv4 and IPv6:
$ curl -ikL4 http://research-software.org/.well-known/acme-challenge/file.html
Date: Fri, 23 Feb 2018 09:27:52 GMT
Content-Length: 194
Location: https://research-software.org/.well-known/acme-challenge/file.html
HTTP/1.1 200 OK
Content-Length: 13
Last-Modified: Fri, 23 Feb 2018 09:23:20 GMT
ETag: "5a8fdd88-d"
certbot test
$ curl -ikL6 http://research-software.org/.well-known/acme-challenge/file.html
Date: Fri, 23 Feb 2018 09:28:00 GMT
Content-Length: 194
HTTP/1.1 200 OK
Content-Length: 13
ETag: "5a8fdd88-d"
certbot test
Using wissenschaftliche-software.org doesn’t work neither using IPv4 nor IPv6 but the data is different regarding the IPvX protocol used…
$ curl -ikL4 http://wissenschaftliche-software.org/.well-known/acme-challenge/file.html
Date: Fri, 23 Feb 2018 09:29:55 GMT
Content-Length: 194
Content-Length: 194
HTTP/1.1 200 OK
<!DOCTYPE html>
<html lang="en"><!--
 __  __                __                                     __
/\ \/\ \              /\ \             __                    /\ \
\ \ \_\ \   __  __    \_\ \      __   /\_\      __       ___ \ \ \/'\
 \ \  _  \ /\ \/\ \   /'_` \   /'__`\ \/\ \   /'__`\    /'___\\ \ , <
  \ \ \ \ \\ \ \_\ \ /\ \L\ \ /\  __/  \ \ \ /\ \L\.\_ /\ \__/ \ \ \\`\
   \ \_\ \_\\/`____ \\ \___,_\\ \____\ _\ \ \\ \__/.\_\\ \____\ \ \_\ \_\
    \/_/\/_/ `/___/> \\/__,_ / \/____//\ \_\ \\/__/\/_/ \/____/  \/_/\/_/
                /\___/                \ \____/
                \/__/                  \/___/
[more html removed]
$ curl -ikL6 http://wissenschaftliche-software.org/.well-known/acme-challenge/file.html
Date: Fri, 23 Feb 2018 09:33:18 GMT
Content-Length: 178
<html>
<hr><center>nginx/1.10.3 (Ubuntu)</center>
</body>
</html>
Yes, I’ve just realized that as well. Weird. Must be an nginx setup problem, as it seems changes in the setup in sites-available aren’t picked up. I’ll try to fix this and get back.
Thanks for your help so far!
Okay, fixed the original issue by properly setting up all domain configs again. Seems like I hadn’t managed to set up IPv6 correctly for the multi-domain usage.
Now I’m running into https://github.com/certbot/certbot/issues/5550, but there’s a workaround available so I’ll just try this for now.
Thanks!
Issue can be closed.
