My domain is: webclass.co.in
I ran this command: sudo certbot --nginx
Domain: webclass.co.in
Detail: 2a02:4780:12:237b::1: Invalid response from http://webclass.co.in/.well-known/acme-challenge/aYzaidj1V_zqOI6IR6FfUNf7qclgtadgUTBZKezo1JE: 404
Domain: www.webclass.co.in
Detail: 2a02:4780:12:237b::1: Invalid response from http://www.webclass.co.in/.well-known/acme-challenge/V55xdVTVSe91ZWeVcaIXFnp51dP10r9Q3-xqTO1xu_c: 404
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.```
My web server is (include version): nginx version: nginx/1.21.4
The operating system my web server runs on is (include version): Ubuntu 22.0.4
My hosting provider, if applicable, is: Hostinger
The version of my client is (e.g. output of `certbot --version` or `certbot-auto --version` if you're using Certbot): certbot 2.8.0
Lets Debug is showing no issues - https://letsdebug.net/webclass.co.in/2316527
https://www.nslookup.io/domains/webclass.co.in/webservers/ It also seems to be pointing to the correct IP Address.
Same on DNS Checker - https://dnschecker.org/#A/webclass.co.in
Please help and assist. I have been working for several hours
